Workspace id to begin with 0 instead of 1
i am using miryoku layout miryoku/docs/reference at master · manna-harbour/miryoku · GitHub which has numbers in keypad format.
Currently workspace don’t start with 0 instead they start with 1.
i wanted to have 0 workspace as starting workspace when hyprland starts. And place pre-defined applications in workspace 1 onward. As this will provide logical grouping to the keypad layout that i have phycally.
if it can be a breaking change, can we get it as a config, disabled by default.
Misinterpreted your title. At first I thought to myself, ‘he’s running hyprland as root; you shouldn’t do that.’ :slightly_smiling_face:
Yeah, I re-wrote the title to be more clear. Thanks.
No. What’s even the point? You can interpret your workspaces however you want.
Yes, but relative commands like hyprctl dispatch workspace -1breaks.
ok, on second thought, i can just remap the following ways →
  • key 0 → workspace 1
  • key 1 → workspace 2
  • key 2 → workspace 3
  • so on
That’s what I meant, yeah
