Vertical Monitor: Layout
I need help re-creating/emulating my vertical monitor layout from AwesomeWM to Hyprland. I dont even know which “layout plugin” can achieve this
The desired effect is for the windows to stack on top of each other
Desired Windows Sizes
if only 1 window is on screen: window_1 = (2/3 of the screen) + “a little more”
if only 2 windows are on screen: window_1 = (2/3 of the screen), window_2 = (1/3 of the screen)
else if 3 or more windows are on screen: Each window is divided equally in size
my layout is a modified version of Bling’s horizontal.lua for AwesomeWM
local mylayout = {}
mylayout.name = "my_custom_layout"
-- Arrange clients in a horizontal layout from top to bottom
-- What is "p"? I think current monitor
function mylayout.arrange(p)
	local screen_area = p.workarea -- Available screen area for the layout
	local t = screen[p.screen].selected_tag -- Selected tag
	local master_count = math.min(t.master_count, #p.clients) -- Number of Master clients
	local slave_count = #p.clients - master_count -- Number of Slave clients
	local master_height = screen_area.height / #p.clients -- Default height for Master area
	local slave_height = screen_area.height - master_height -- Default height for Slave area
	-- Special Case: 1 Master client and 0 Slave clients
	if master_count == 1 and slave_count == 0 then
		master_height = screen_area.height - (screen_area.height / 3) + 150 -- Custom Height
		p.geometries[p.clients[1]] = {
			x = screen_area.x,
			y = screen_area.y + screen_area.height - master_height,
			width = screen_area.width,
			height = master_height,
		return
	-- Special Case: 1 Master client and 1 Slave client
	if master_count == 1 and slave_count == 1 then
		master_height = screen_area.height / 3
	-- Arrange Master clients from top to bottom
	for idx = 1, master_count do
		p.geometries[p.clients[idx]] = {
			x = screen_area.x, -- X position for Master client
			y = screen_area.y, -- Y position for Master client
			width = screen_area.width, -- Width for Master client
			height = master_height, -- Height for Master client
	-- Arrange Slave clients from top to bottom
	for idx = 1, slave_count do
		p.geometries[p.clients[idx + master_count]] = {
			x = screen_area.x, -- X position for Slave client
			y = screen_area.y + master_height + (idx - 1) * (slave_height / slave_count), -- Y position starts above the Master client and is distributed vertically from top to bottom
			width = screen_area.width, -- Width for Slave client
			height = slave_height / slave_count, -- Height for each Slave client
return mylayout
Simply: you can’t.
You will be able to with layout/dwindle: add presets by vaxerski · Pull Request #11629 · hyprwm/Hyprland · GitHub though.
