I’m trying to automate switching between workspaces using hyperctl, and have just been testing out the commands in the terminal to make sure they work. However, I keep getting this error about syntax (see the blockquote below for my terminal outputs) and I’m not sure of a way around it. Does anyone here know the correct syntax?
[alcme@stupid-twinkpad~]$ hyprctl dispatch focus{workspace=3}
error: [string “return hl.dispatch(focus{workspace=3})”]:1: attempt to call a nil value (global ‘focus’)-> Note: dispatch in lua is a shorthand for hl.dispatch(…), your syntax might need to be updated.
[alcme@stupid-twinkpad~]$ hyprctl dispatch workspace 3
error: [string “return hl.dispatch(workspace 3)”]:1: ‘)’ expected near ‘3’-> Note: dispatch in lua is a shorthand for hl.dispatch(…), your syntax might need to be updated.
(I’ve tried other variations than the ones shown, none have worked :c)
