Tooltips steal focus from parent window, parent gets blurred and dimmed
Hyprland 0.53.1 built from branch v0.53.1 at commit ab1d80f3d6aebd57a0971b53a1993b1c1dfe0b09 clean (version: bump to 0.53.1).Date: Fri Jan 2 21:20:57 2026Tag: v0.53.1, commits: 6766
Hyprlang: built against 0.6.7, system has 0.6.8
Version ABI string: ab1d80f3d6aebd57a0971b53a1993b1c1dfe0b09_aq_0.10_hu_0.11_hg_0.5_hc_0.1_hlg_0.6
Hi there
Some apps (e.g. MetiathekView, MetaTrader5 with wine), when opening a tooltip, they loose their focus. Not always the input focus (keyboard), but the “visual” focus. I only realized that, because I am using things like inactive_opacity and dim_inactive in my hprland config. When a tooltip opens, the main window is dimmed and blurred.
Okay, even a tooltip is a window, but it should not get any sort of focus when opened.
Is this a bug in the apps? Or something, that hyprland should handle differently?
Can I change something in my config to fix it? But please not inactive_opacityand dim_inactive :blush:
Regards
Peter
