Today's Arch package release (0.51.1-2) and Nautilus rendering glitches
`0.51.1-2`
I’m also creating an issue for the Arch package, but wondering if anyone else is experiencing rendering glitches in Nautilus after upgrading to 0.51.1-2.
Specifically, after upgrading today, when I launch Nautilus (Omarchy default), and I mouse over the window, artifacts from the wallpaper bleed through into both folder icons and menus. This is the first time seeing this behavior.
Got the same problem.
See:
-and-
Fixed by: math/region: reinit region for scale() · hyprwm/hyprutils@9ab6431 · GitHub
Fixed in: Release v0.10.0 · hyprwm/hyprutils · GitHub
EDIT: The whole rebuilt stack is now in the [testing] repo.
$ hyprctl version
Hyprland 0.51.0 built from branch main at commit 76d998743ac10e712238c1016db4d8e8d16f1049 dirty (cm: handle inert cm outputs (11916)).
Date: Fri Oct 3 18:35:22 2025
Tag: v0.51.0-58-g76d998743, commits: 6476
 aquamarine 0.9.5
 hyprutils 0.10.0
 hyprgraphics 0.2.0
flags set:
no xwayland
As above, it was a weird oopsie with a third-party library’s not-very-intuitive and undocumented design. I might get rid of that dep in the future…
