Single shot timer?
In the wiki we can see how to use timers:
local demoTimer = hl.timer(function()
  print("hello from timer")
end, { timeout = 1000, type = "repeat" })
type = "repeat" means, this timer runs forever or until it is disabled:
demoTimer:set_enabled(false)
Is there a way to create a single shot timer that triggers only one time?
What other types are possible instead of type = "repeat"?
Thanks
Peter
end, { timeout = 1000, type = "oneshot" })
Oh, yes, it works. Thank you!
From where do you know this? From where could I have known this?
Regards
Peter
The stub:
"HL.TimerOptions",
                ("timeout", "integer", False),
                ("type", '"repeat"|"oneshot"', False),
---@class HL.TimerOptions
 467 │ ---@field timeout integer
 468 │ ---@field type "repeat"|"oneshot"
 469 │ local __HL_TimerOptions = {}
Oh, yeah, thank you.
I found the second part in /usr/share/hypr/stubs/hl.meta.lua.
Where do I find the first part?
In the script which generates the latter:
