Set Default Workspace to start with after starting Hyprland
Hyprland 0.55.0 built from branch v0.55.0
Hi,
I’m using a two-monitor setup (main + external monitor) on Hyprland 0.55.
By default, Hyprland always starts on Workspace 1. I’d like it to start on Workspace 6 instead.
Earlier, I used this workaround:
exec-once = hyprctl dispatch workspace 6
but I’m not sure if this is still the recommended approach in newer versions.
What is the correct/preferred way to set the startup workspace in Hyprland 0.55?
Thanks in advance.
The answer is in the wiki, along with an example…
(post deleted by author)
Tried but didnt work.
I also tried setting this in the config
'hl.dispatch(hl.dsp.focus({ workspace = "6" }))' as
hl.on("hyprland.start", function ()
I do get the control in workspace = 6 (i.e. on External Monitor) but my mouse cursor is on Workspace = 1 (i.e. Main Monitor)
