Screen deadzones for mouse
first off just setup hyprland today.
hello i am havign a weird issue, the same one as in this girhub disscusion, Multi-monitor cursor bug · hyprwm/Hyprland · Discussion #10969 · GitHub
basicaly there are zones on my 2 vertical lg monitors that for some reason my mouse can’t go,
the right 1/8 of my first screen and the bottom 8th of the same moddel of monitor next to it. hyprland has no issue displaying there but my mouse just can’t go there.
systeminfo
-/oyddmdhs+:. c2@gentoobtw
-odNMMMMMMMMNNmhy±` ------------
-yNMMMMMMMMMMMNNNmmdhy± OS: Gentoo Linux x86_64
omMMMMMMMMMMMMNmdmmmmddhhy/ Kernel: Linux 6.17.8-cachyos
omMMMMMMMMMMMNhhyyyohmdddhhhdo Uptime: 1 hour, 58 mins .ydMMMMMMMMMMdhs++so/smdddhhhhdm+ Packages: 2274 (emerge), 33 (flatpak-system), 1 (flatpak-user)
oyhdmNMMMMMMMNdyooydmddddhhhhyhNd. Shell: bash 5.3.3
:oyhhdNNMMMMMMMNNNmmdddhhhhhyymMh Display (XV275K): 3840x2160 @ 1.25x in 27", 60 Hz [External]
.:+sydNMMMMMNNNmmmdddhhhhhhmMmy Display (LG FULL HD): 1080x1920 in 22", 60 Hz [External]
/mMMMMMMNNNmmmdddhhhhhmMNhs: Display (LG FULL HD): 1080x1920 in 22", 60 Hz [External]
oNMMMMMMMNNNmmmddddhhdmMNhs+ Display (Odyssey G7): 3840x2160 in 32", 165 Hz [External]
sNMMMMMMMMNNNmmmdddddmNMmhs/. WM: Hyprland 0.51.1 (Wayland) /NMMMMMMMMNNNNmmmdddmNMNdso: Theme: Breeze-Dark [GTK2], Breeze [GTK3/4]
+MMMMMMMNNNNNmmmmdmNMNdso/- Icons: Vivid-Dark-Icons [GTK2/3/4]
yMMNNNNNNNmmmmmNNMmhs+/- Font: Noto Sans (10pt) [GTK2/3/4] /hMMNNNNNNNNMNdhs++/- Cursor: breeze (24px)
/ohdmmddhys+++/:. Terminal: kitty 0.44.0
`-//////:–. Terminal Font: LiberationMono (11pt)
CPU: AMD Ryzen 9 9950X3D (32) @ 5.76 GHz
GPU 1: AMD Radeon RX 7900 XTX [Discrete]
GPU 2: AMD Radeon RX 6600 [Discrete]
gpu driver: AMD Radeon RX 6600 (radeonsi, navi23, LLVM 20.1.8, DRM 3.64, 6.17.8-cachyos)
Memory: 7.90 GiB / 93.94 GiB (8%)
Swap: 0 B / 16.00 GiB (0%)
Disk (/): 741.66 GiB / 914.07 GiB (81%) - xfs
Disk (/run/media/hdd): 5.03 TiB / 10.83 TiB (46%) - ext4
Disk (/run/media/pciessd): 62.18 GiB / 476.71 GiB (13%) - xfs
Disk (/run/media/wdssd): 1.02 TiB / 1.82 TiB (56%) - xfs
Locale: C.utf8
c2@gentoobtw ~ $ emerge -pv gui-wm/hyprland
  • IMPORTANT: config file ‘/etc/portage/package.accept_keywords/keywords’ needs updating.
  • See the CONFIGURATION FILES and CONFIGURATION FILES UPDATE TOOLS
  • sections of the emerge man page to learn how to update config files.
These are the packages that would be merged, in order:
Calculating dependencies… done!
Dependency resolution took 1.38 s (backtrack: 0/20).
[ebuild R ~] gui-wm/hyprland-0.51.1::gentoo USE=“X qtutils systemd” 53010 KiB
Total: 1 package (1 reinstall), Size of downloads: 53010 KiB
c2@gentoobtw ~ $
systeminfo
Locale: C.utf8
c2@gentoobtw ~ $
any one know how i edit it so that the fastfetch works normal 3 backticks at the start and end of a section dose that
