Scratchpads(float) are not scalling good from my 4k monitor to my laptop
I am using latest hyprland-git using lua and working great, but I just start using hyprland’s scratch pads. The only issue I have is when going from my docking setup(big monitor) to my laptop screen, my scratchpads aren’t transferring with correct size.
local function apply_monitor_config()
local monitors = hl.get_monitors()
local big_monitor_name = nil
-- Loop through active screens and find any HDMI-A output
for _, m in ipairs(monitors) do
    if m.name and m.name:match("^HDMI%-A") then
        big_monitor_name = m.name
        break
-- Apply layouts based on detection
if big_monitor_name then
    -- Big monitor on the left
    hl.monitor({
        output   = big_monitor_name,
        mode     = "3840x2160@60",
        position = "0x0",
        scale    = "1",
    -- Laptop screen on the right
    hl.monitor({
        output    = "eDP-1",
        disabled  = true,
else
    -- Fallback: Laptop screen only when disconnected from the KVM
    hl.monitor({
        output   = "eDP-1",
        disabled = false,
        mode     = "1920x1080@60",
        position = "0x0",
        scale    = "1",
-- -- Re-bind special workspaces to active output so geometry re-evaluates nativel
-- Restart Waybar cleanly
hl.exec_cmd("systemctl --user restart waybar")
-- Respawn terminals on the new active resolution
-- monitor_w and monitor_h in windowrules.lua will evaluate against the current display
-- Connect the configuration handler to Hyprland’s window manager event hooks
–hl.on(“config.reloaded”, apply_monitor_config)
hl.on(“monitor.added”, apply_monitor_config)
hl.on(“monitor.removed”, apply_monitor_config)
-- Run the check immediately on initialization
hl.window_rule({
name = “kitty_dropterm_scratchpad”,
match = { class = “kitty-dropterm” },
float = true,
size = { “monitor_w * 0.7”, “monitor_h * 0.7” },
center = true,
stay_focused = true,
workspace = “special:term silent”,
hl.window_rule({
name = “kitty_dropneomutt_scratchpad”,
match = { class = “kitty-dropneomutt” },
float = true,
center = true,
workspace = “special:neomutt silent”,
hl.window_rule({
name = “kitty_dropyazi_scratchpad”,
match = { class = “kitty-dropyazi” },
float = true,
center = true,
workspace = “special:yazi silent”,
hl.window_rule({
name = “kitty_dropcmus_scratchpad”,
match = { class = “kitty-dropcmus” },
float = true,
center = true,
workspace = “special:cmus silent”,
