I am running Hyprland for the first time after wanting to for a long time. As a fellow software engineer I know the struggles of developing open source software. I want to support hyprland, because in the Linux world, it is even more important, more so than ever before.
My question is, how would hyprperks help me out on Omarchy? Would they work well there?
They’d conflict. Both are a set of dotfiles, really.
Ok, so what would you recommend I do to help pay for hyprland? Just get a hyprperks account anyway?
You can donate with a regular donations.
You can donate with “hyprperks” and just not install it.
Pretty sure vaxry said in some other topic that the payouts after stripe(hyprperks) tax or their regular donation service are the same or similar, but might be wrong on this
As above. The final amount for me is similar both ways, donating is more flexible for you as you can pick the amount.
