Is there a hyprland equivalent of ‘xrandr -o right’?
I have trawled google and gemini and have found the wayland equivalent of the command but it does not work with hyprland.
You can set the rotation with the transform keyword in the config
I am sure there is a way to use hyprctl to set it as well if you absolutely need it to be a command, but I’m not sure what that would be.
Many thanks. I will go have a play.
Sorted:
hyprctl keyword monitor,preferred,auto,1,transform,3
