❯ hyprctl version
Hyprland 0.50.0 built from branch at commit c4a4c341568944bd4fb9cd503558b2de602c0213 (version: bump to 0.50.0).
Date: Wed Jul 16 09:33:42 2025
Tag: v0.50.0, commits: 6279
aquamarine 0.9.1
hyprutils 0.8.1
output of hyprctl systeminfo -c
aquamarine 0.9.1
hyprutils 0.8.1
System Information:
System name: Linux
Node name: SMPC
Release: 6.15.7-arch1-1
Version: #1 SMP PREEMPT_DYNAMIC Thu, 17 Jul 2025 21:05:29 +0000
GPU information:
03:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900 XTX/7900 GRE/7900M] [1002:744c] (rev c8) (prog-if 00 [VGA controller])
15:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Raphael [1002:164e] (rev c9) (prog-if 00 [VGA controller])
os-release: NAME="Arch Linux"
PRETTY_NAME="Arch Linux"
ID=arch
BUILD_ID=rolling
ANSI_COLOR="38;2;23;147;209"
HOME_URL="https://archlinux.org/"
DOCUMENTATION_URL="https://wiki.archlinux.org/"
SUPPORT_URL="https://bbs.archlinux.org/"
BUG_REPORT_URL="https://gitlab.archlinux.org/groups/archlinux/-/issues"
PRIVACY_POLICY_URL="https://terms.archlinux.org/docs/privacy-policy/"
LOGO=archlinux-logo
plugins:
hy3 by outfoxxed ver 0.1
======Config-Start======
Config File: /home/smitropoulos/.config/hypr/hyprland.conf: Read Succeeded
# │ Set programs that you use │
# See https://wiki.hyprland.org/Configuring/Keywords/ for more
$mod = SUPER
$terminal = kitty
$fileManager = nemo
$browser = brave
$menu = albert toggle
$lock_screen = hyprlock
$idler = hypridle
# │ Monitor Configs │
source = ~/.config/hypr/config/monitors.conf
# │ Autostart background │
source = ~/.config/hypr/config/autostart.conf
# │ Settings │
source = ~/.config/hypr/config/general.conf
# │ Plugin settings │
source = ~/.config/hypr/config/plugins.conf
# │ basic keybinds │
source = ~/.config/hypr/config/keybinds.conf
# │ Workspaces │
source = ~/.config/hypr/config/workspaces.conf
# │ Window rules │
source = ~/.config/hypr/config/rules.conf
Config File: /home/smitropoulos/.config/hypr/config/monitors.conf: Read Succeeded
# ─[ source https://wiki.hyprland.org/Configuring/Monitors/#general ]─────
$dell_monitor = desc:Dell Inc. DELL P2416D 07C536950FKU
$LG_monitor = desc:LG Electronics LG ULTRAGEAR 209MAMBFWE23
$AOC_monitor = desc:AOC Q27P1B GNXKBHA113837
$SAMSUNG_G8 = desc:Samsung Electric Company Odyssey G85SB H1AK500000
# $SAMSUNG_G8 = DP-1
$monitor_left = $LG_monitor
$monitor_center = $SAMSUNG_G8
$monitor_right = $monitor_center
monitorv2 {
output = $monitor_left
mode = 2560x1440@144
transform = 3
position = 0x0
scale = 1
bitdepth = 10
# cm = hdr
vrr = 3
supports_wide_color = 1
supports_hdr = 1
sdrbrightness = 1.15
sdrsaturation = 1.0
sdr_min_luminance = 0.005
sdr_max_luminance = 200
min_luminance = 0
max_luminance = 1000
max_avg_luminance = 200
monitorv2 {
output = $monitor_center
mode = 3440x1440@175
position = 1440x560
scale = 1
bitdepth = 10
# cm = hdr
vrr = 3
supports_hdr = 1
sdrsaturation = 1.0
min_luminance = 0
# Default rule fallback
monitor = ,preferred,auto,auto
# experimental {
# xx_color_management_v4 = true
render {
cm_fs_passthrough = 0
cm_auto_hdr = 2
Config File: /home/smitropoulos/.config/hypr/config/autostart.conf: Read Succeeded
exec-once = sleep 3 && hyprpm reload -n
exec-once = $terminal --title kitty_scratchpad
exec-once = wl-paste --type text --watch cliphist store #Stores only text data
exec-once = wl-paste --type image --watch cliphist store #Stores only image data
exec-once = albert
exec-once = dunst
exec-once = systemctl --user start hyprpolkitagent
exec-once = dbus-update-activation-environment --systemd WAYLAND_DISPLAY XDG_CURRENT_DESKTOP
exec-once = $idler
exec-once = sway-audio-idle-inhibit &
# Auto mounting devices
exec-once = udiskie -s
# wallpapers
exec-once = systemctl --user start hyprpaper
# Night-shift
exec-once = gammastep
exec-once = easyeffects --gapplication-service
# Tmux envs
exec-once = sleep 3 && ~/.config/hypr/import_env.sh tmux && ~/.config/hypr/import_env.sh system
exec-once = waybar -c /home/smitropoulos/.config/waybar/config_hyprland
# │ Autostart on workspaces │
exec-once = [workspace 1 silent] $browser
exec-once = [workspace 2 silent] kitty --hold sh -c "tmux attach-session -t 0 || tmux"
exec-once = [workspace 4 silent] $fileManager
exec-once = [workspace 5 silent] steam
exec-once = [workspace 9 silent] thunderbird
exec-once = [workspace 10 silent] spotify-launcher
Config File: /home/smitropoulos/.config/hypr/config/general.conf: Read Succeeded
# │ Cursor settings │
env = HYPRCURSOR_THEME,capitaine-cursors-light
env = HYPRCURSOR_SIZE,24
env = XCURSOR_THEME,capitaine-cursors-light
env = XCURSOR_SIZE,24
# │ Settings │
general {
gaps_in = 5
gaps_out = 8
border_size = 3
col.active_border = rgba(16,183,127,0.5) rgba(99,178,184,0.5) rgba(130,89,156,0.5) 45deg
col.inactive_border = rgba(110,115,141,0.5)
layout = hy3
input {
kb_layout = us, gr
kb_options = grp:alt_shift_toggle
repeat_delay = 190
repeat_rate = 35
sensitivity = 0
# 0 - Cursor movement will not change focus.
# 1 - Cursor movement will always change focus to the window under the cursor.
# 2 - Cursor focus will be detached from keyboard focus. Clicking on a window will move keyboard focus to that window.
# 3 - Cursor focus will be completely separate from keyboard focus. Clicking on a window will not change keyboard focus.
follow_mouse = 1
mouse_refocus = false
debug {
error_position = 1
disable_logs = false
misc {
vrr = 0
mouse_move_enables_dpms = true
key_press_enables_dpms = true
disable_splash_rendering = true
decoration {
shadow {
color = 0xff0f0f0f
rounding = 4
blur {
enabled = true
animations {
enabled = yes
bezier = overshot, 0.25,0.9,0.1,1.1
animation = windows, 1, 9, overshot
animation = windowsOut, 1, 7, overshot, popin 80%
animation = border, 1, 10, overshot
animation = fade, 1, 7, overshot
animation = workspaces, 1, 4, overshot, slidefadeavert
animation = specialWorkspace, 1, 4, overshot, slidefadevert
Config File: /home/smitropoulos/.config/hypr/config/plugins.conf: Read Succeeded
plugin {
hy3 {
node_collapse_policy =1
tabs {
height = 24
padding = 4
render_text = true
text_center = true
text_height = 11
# tab bar border width
border_width = 1
# active tab bar segment color
col.active = rgba(16,185,129,0.6)
col.active.border = rgba(16,185,129,0.1)
# # urgent tab bar segment color
col.urgent = rgba(230,77,77,0.6)
col.urgent.border = rgba(230,77,77,0.9)
# # inactive tab bar segment color
col.inactive = rgba(16,185,129,0.1)
col.inactive.border = rgba(16,185,129,0.1)
# opacity multiplier for tabs
# Applies to blur as well as the given colors.
opacity = 0.65
autotile {
enable = false
trigger_width = 1000
trigger_height = 1000
Config File: /home/smitropoulos/.config/hypr/config/keybinds.conf: Read Succeeded
# │ Keybinds │
# ─[ bar ]────────────────────────────────────────────────────────────────
bind = SUPER,M,exec,waybar -c /home/smitropoulos/.config/waybar/config_hyprland &
bind = SUPERSHIFT,M,exec,killall waybar
# ─[ resize binds ]───────────────────────────────────────────────────────
bindm = SUPER,mouse:272,movewindow
bindm = SUPER,mouse:273,resizewindow
bindn = , mouse:272, hy3:focustab, mouse
bindn = , mouse_down, hy3:focustab, l, require_hovered
bindn = , mouse_up, hy3:focustab, r, require_hovered
bind = SUPER,Q,hy3:killactive
bind = SUPERCTRLSHIFT,E,exec, uwsm stop
bind = SUPERSHIFT,space,togglefloating
bind = SUPER,space,exec,albert toggle
# bind = SUPER,space,exec,killall rofi > /dev/null 2>&1|| rofi -show combi -combi-modes "drun, run" -modes combi
bind = SUPERSHIFT,space,pseudo
bind = SUPER,F,fullscreen
# ─[ Screenshotting ]─────────────────────────────────────────────────────
bind = ,Print, exec, hyprshot --mode output --output-folder ~/Pictures/Screenshots/
bind = SHIFT, Print, exec, hyprshot --mode region --output-folder ~/Pictures/Screenshots/
# ─[ Kitty ]──────────────────────────────────────────────────────────────
bind = SUPER,RETURN,exec,$terminal
# bind=CTRLALT,T,exec,kitty -o 'font_size=13' --title ok_its_kitty
# bind=SUPER,t,exec,kitty --start-as=fullscreen -o 'font_size=18' --title all_is_kitty
# bind=SUPER,N,exec,nvim
# bind=SUPER,I,exec,kitty --title ok_its_kitty --hold nmtui
# bind=SUPER,Y,exec,kitty --title ok_its_kitty --hold yay
# ─[ Gaming ]───────────────────────────────────────────────────────────
bind = SUPER,F11,exec,~/.config/hypr/cursorlock.sh
# ─[ lock screen ]────────────────────────────────────────────────────────
bind = SUPER,escape,exec, pkill remmina;playerctl pause;sleep 1; $lock_screen
bind = SUPERSHIFT,escape,exec, systemctl suspend
bind = SUPER,X,exec, wlogout --protocol layer-shell
# ─[ Colorschemes ]─────────────────────────────────────────────────────
bind = SUPER,F2,exec, ~/scripts/utility/colorschemes/changeColorscheme.sh
# ─[ binds for workspaces ]───────────────────────────────────────────────
# ─[ focusing windows ]───────────────────────────────────────────────────
bind = SUPER,left,hy3:movefocus,l
bind = SUPER,right,hy3:movefocus,r
bind = SUPER,up,hy3:movefocus,u
bind = SUPER,down,hy3:movefocus,d
# vim-keybinds
bind = SUPER,h,hy3:movefocus,l
bind = SUPER,l,hy3:movefocus,r
bind = SUPER,k,hy3:movefocus,u
bind = SUPER,j,hy3:movefocus,d
# ─[ moving windows ]─────────────────────────────────────────────────────
bind = SUPERSHIFT,left,hy3:movewindow,l
bind = SUPERSHIFT,right,hy3:movewindow,r
bind = SUPERSHIFT,up,hy3:movewindow,u
bind = SUPERSHIFT,down,hy3:movewindow,d
# vim-keybinds
bind = SUPERSHIFT,h,hy3:movewindow,l
bind = SUPERSHIFT,l,hy3:movewindow,r
bind = SUPERSHIFT,k,hy3:movewindow,u
bind = SUPERSHIFT,j,hy3:movewindow,d
# ─[ workspaces ]─────────────────────────────────────────────────────────
# ─[ focusing other workspaces ]──────────────────────────────────────────
bind = SUPER,1,workspace,1
bind = SUPER,2,workspace,2
bind = SUPER,3,workspace,3
bind = SUPER,4,workspace,4
bind = SUPER,5,workspace,5
bind = SUPER,6,workspace,6
bind = SUPER,7,workspace,7
bind = SUPER,8,workspace,8
bind = SUPER,9,workspace,9
bind = SUPER,0,workspace,10
# ─[ Tabbed ]─────────────────────────────────────────────────────────────
bind = $mod, e, hy3:changegroup, opposite
bind = $mod, w, hy3:makegroup, tab
bind = $mod, a, hy3:changefocus, raise
bind = $mod+SHIFT, a, hy3:changefocus, lower
# ─[ moving windows to other workspaces ]─────────────────────────────────
bind = SUPERSHIFT,1,movetoworkspace,1
bind = SUPERSHIFT,2,movetoworkspace,2
bind = SUPERSHIFT,3,movetoworkspace,3
bind = SUPERSHIFT,4,movetoworkspace,4
bind = SUPERSHIFT,5,movetoworkspace,5
bind = SUPERSHIFT,6,movetoworkspace,6
bind = SUPERSHIFT,7,movetoworkspace,7
bind = SUPERSHIFT,8,movetoworkspace,8
bind = SUPERSHIFT,9,movetoworkspace,9
bind = SUPERSHIFT,0,movetoworkspace,10
# ─[ moving windows to other workspaces (silent) ]────────────────────────
bind = SUPERCTRL,1,movetoworkspacesilent,1
bind = SUPERCTRL,2,movetoworkspacesilent,2
bind = SUPERCTRL,3,movetoworkspacesilent,3
bind = SUPERCTRL,4,movetoworkspacesilent,4
bind = SUPERCTRL,5,movetoworkspacesilent,5
bind = SUPERCTRL,6,movetoworkspacesilent,6
bind = SUPERCTRL,7,movetoworkspacesilent,7
bind = SUPERCTRL,8,movetoworkspacesilent,8
bind = SUPERCTRL,9,movetoworkspacesilent,9
bind = SUPERCTRL,0,movetoworkspacesilent,10
# ─[ moving to other wokspace with mouse control ]────────────────────────
bind = SUPER,mouse_down,workspace,e-1
bind = SUPER,mouse_up,workspace,e+1
# ─[ simple movement between spaces ]─────────────────────────────────────
bind = SUPER,u,togglespecialworkspace
bind = SUPER,minus,movetoworkspace,special
# ─[ Audio ]──────────────────────────────────────────────────────────────
bind = ,XF86AudioPlay,exec,playerctl play-pause
bind = ,XF86AudioPrev,exec,playerctl previous
bind = ,XF86AudioNext,exec,playerctl next
bindl = ,XF86AudioMedia,exec,playerctl play-pause
bindl = ,XF86AudioStop,exec,playerctl stop
# Use pactl to adjust volume in PulseAudio.
bindle = ,XF86AudioRaiseVolume,exec, pactl set-sink-volume @DEFAULT_SINK@ +5%
bindle = ,XF86AudioLowerVolume,exec, pactl set-sink-volume @DEFAULT_SINK@ -5%
bindle = ,XF86AudioMute,exec, pactl set-sink-mute @DEFAULT_SINK@ toggle
bindle = ,XF86AudioMicMute,exec, pactl set-source-mute @DEFAULT_SOURCE@ toggle
# ─[ brightness ]─────────────────────────────────────────────────────────
bindle = ,XF86MonBrightnessUp,exec,brightnessctl set 5%+
bindle = ,XF86MonBrightnessDown,exec,brightnessctl set 5%-
# │ Resize │
# will switch to a submap called resize
bind = SUPER,R,submap,resize
# will start a submap called "resize"
submap = resize
# sets repeatable binds for resizing the active window
binde = ,L,resizeactive,40 0
binde = ,H,resizeactive,-40 0
binde = ,K,resizeactive,0 -40
binde = ,J,resizeactive,0 40
# use reset to go back to the global submap
bind = ,escape,submap,reset
bind = ,Return,submap,reset
# will reset the submap, meaning end the current one and return to the global one
submap = reset
Config File: /home/smitropoulos/.config/hypr/config/workspaces.conf: Read Succeeded
# ─[ Workspaces bindings ]────────────────────────────────────────────────
workspace = 1,monitor:$monitor_left,default:true
workspace = 2,monitor:$monitor_center,default:true
workspace = 3,monitor:$monitor_right,default:true
workspace = 4,monitor:$monitor_left
workspace = 5,monitor:$monitor_center
workspace = 6,monitor:$monitor_right
workspace = 7,monitor:$monitor_left
workspace = 8,monitor:$monitor_center
workspace = 9,monitor:$monitor_right
workspace = 10,monitor:$monitor_left
Config File: /home/smitropoulos/.config/hypr/config/rules.conf: Read Succeeded
# │ Window rules │
# ─[ Kitty on the scratchpad ]──────────────────────────────────────────
windowrulev2 = float, class:(kitty), title:(kitty_scratchpad)
windowrulev2 = workspace special silent,class:(kitty), title:(kitty_scratchpad)
windowrulev2 = center 1, class:(kitty), title:(kitty_scratchpad)
windowrulev2 = size 2928 1168, class:(kitty), title:(kitty_scratchpad)
windowrulev2 = monitor 0, class:(kitty), title:(kitty_scratchpad)
# ─[ Steam focus ]──────────────────────────────────────────────────────
# Steam do not steal focus
windowrulev2 = workspace 5 silent,class:(\bsteam\b)
windowrulev2 = noinitialfocus, class:(\bsteam\b)
windowrulev2 = minsize 1 1, title:^()$,class:^(steam)$
windowrulev2 = idleinhibit focus, class:(\bsteam\b)
windowrulev2 = tag +game, class:(steam_app_\d+)
# ─[ Battlenet focus ]──────────────────────────────────────────────────
$battle_net_class=battle\.net\..*
windowrulev2 = workspace 5 silent,class:($battle_net_class)
windowrulev2 = noinitialfocus, class:($battle_net_class)
windowrulev2 = suppressevent activatefocus, class:($battle_net_class)
windowrulev2 = tag +game, class:($battle_net_class)
$dota2_class=dota2
windowrulev2 = tag +game, class:($dota2_class)
# ─[ New e-mail float ]─────────────────────────────────────────────────
windowrulev2 = tag +floaters, class:(thunderbird)
windowrulev2 = tag +60s, class:(thunderbird)
windowrulev2 = workspace 9 silent,class:(thunderbird)
# ─[ Thunderbird only main no float ]───────────────────────────────────
windowrulev2 = tile, class:(thunderbird), title:(.*Mozilla.Thunderbird.*)
windowrulev2 = workspace 9 silent, class:(thunderbird), title:(.*Mozilla.Thunderbird.*)
# ─[ File popup float ]─────────────────────────────────────────────────
windowrulev2 = tag +floaters, class:(Xdg-desktop-portal.*)
windowrulev2 = tag +noeffects, class:(Xdg-desktop-portal.*)
$file_folder_str = Open|Select|Save .*Image[s]?.*|.*File[s]?.*|.*Folder[s]?.*|.*Document[s]?.*
windowrulev2 = tag +floaters, title:($file_folder_str)
windowrulev2 = tag +60s, title:($file_folder_str)
# ─[ KDEConnect float ]─────────────────────────────────────────────────
$kde_class_str=org.kde.kdeconnect.*
windowrulev2 = tag +floaters, class:($kde_class_str)
windowrulev2 = tag +60s, title:($kde_class_str)
# ─[ Polkit float ]─────────────────────────────────────────────────────
$polkit_class_str=org.kde.polkit.*
windowrulev2 = tag +floaters, class:($polkit_class_str)
# ─[ Gnome Apps float ]─────────────────────────────────────────────────
$gnome_class_str=org\.gnome\..*
windowrulev2 = tag +floaters, class:($gnome_class_str)
# ─[ Popups/menu items for e.g. chrome ]────────────────────────────────
windowrulev2 = noblur, floating:1, class:(^$), title:(^$)
# ─[ Albert rules floating ]────────────────────────────────────────────
windowrulev2 = center, floating:1, class:(albert)
windowrulev2 = dimaround, floating:1, class:(albert)
# ─[ Hyprland Picker ]──────────────────────────────────────────────────
$hyprland_share_picker_class_str=hyprland-share-picker
windowrulev2 = tag +floaters, class:($hyprland_share_picker_class_str)
windowrulev2 = tag +60s, class:($hyprland_share_picker_class_str)
# ─[ Pavu ]─────────────────────────────────────────────────────────────
$pavucontrol_class_str=org.pulseaudio.pavucontrol
windowrulev2 = tag +floaters, class:($pavucontrol_class_str), title:(Volume Control)
windowrulev2 = tag +60s, class:($pavucontrol_class_str)
# ─[ OnlyOffice ]───────────────────────────────────────────────────────
$only_office_class_str=DesktopEditors
windowrulev2 = tag +floaters, class:($only_office_class_str)
# ─[ Fullscreen ]───────────────────────────────────────────────────────
windowrulev2 = idleinhibit focus, class:.*, fullscreen:1
# ─[ Tag rules ]────────────────────────────────────────────────────────
# │ This section should be in the end │
# general floaters
windowrulev2 = float, tag:floaters
windowrulev2 = center, tag:floaters
windowrulev2 = dimaround, tag:floaters
# noeffects
windowrulev2 = noblur, tag:noeffects
windowrulev2 = noborder, tag:noeffects
windowrulev2 = noshadow, tag:noeffects
# 60 percents
windowrulev2 = size 60%, tag:60s
# Games
windowrulev2 = float, tag:game
windowrulev2 = monitor 0, tag:game
windowrulev2 = center, tag:game
windowrulev2 = minsize 1 1, tag:game
windowrulev2 = immediate, tag:game
windowrulev2 = noblur, tag:game
windowrulev2 = noborder, tag:game
windowrulev2 = nodim, tag:game
windowrulev2 = noshadow, tag:game
windowrulev2 = noanim, tag:game
windowrulev2 = workspace 5 silent, tag:game
======Config-End========
Hello there,
Coming from Color management support · Issue #9064 · hyprwm/Hyprland · GitHub, I am creating a new discussion on this!
I am trying to enable HDR and automatic HDR on games running on steam.
I have tried multiple games, naming a few:
- Sniper elite 5 / resistance.
- Baldur’s Gate 3
- Blair Witch (this runs natively on linux)
- Red dead redemption 2
- Clair obscur: Expedition 33
Running the games from Steam directly, forcing GE-Proton-latest from the compatibility tab, which would be version 10.10 atm with these settings:
ENABLE_HDR_WSI=1 PROTON_ENABLE_WAYLAND=1 PROTON_ENABLE_HDR=1 gamemoderun %command%
OR
Running
❯ paru -Qe mesa
mesa 1:25.1.6-1
My monitor settings in HL:
monitorv2 {
transform = 3
position = 0x0
scale = 1
bitdepth = 10
# cm = hdr
vrr = 3
supports_hdr = 1
sdrsaturation = 1.0
min_luminance = 0
monitorv2 {
position = 1440x560
scale = 1
bitdepth = 10
# cm = hdr
vrr = 3
supports_hdr = 1
sdrsaturation = 1.0
min_luminance = 0
# experimental {
render {
cm_auto_hdr = 2
Even when I enable the HDR in the monitor settings above, the games either do not have the HDR button enabled (it’s grey’ed out), or the HDR button is completely absent.
I am not sure if this is even the correct way to actually run the games, maybe I am doing something else wrong?
EDIT:
Forgot to mention, auto_hdr does not kick off for me, meaning my monitor does not automatically go into HDR mode
