Hyprland 0.51.1 built from branch at commit 71a1216abcc7031776630a6d88f105605c4dc1c9 ([gha] Nix: update inputs).
Tag: v0.51.1, commits: 6436
aquamarine 0.9.5
hyprutils 0.10.0
hyprgraphics 0.2.0
Focusing back and forth with the dispatch workspace previous works well, but when one uses the dispatch movetoworkspace previous to move windows to the previous workspace it will only work once and then it outputs Invalid workspace in moveActiveToWorkspace. This only seems to happen when movetoworkspace previous is called a second time from empty workspace.
Perhaps this is intented behaviour?
One more thing, using the movetoworkspace previous should only focus back and forth between the workspaces(given that these are not empty), right? Because one can make a cycle of n workspaces with the dispatch movetoworkspace previous:
- have a window open in workspaces “W” through “Wn” (at least one window open otherwise dispatch fails)
- focus once workspace “W” through “Wn”
- focus again workspace “W”
- open a terminal and enter the command
hyprctl dispatch movetoworkspace previous - enter the command again effectively looping through the workspaces infinitely.
I just wish to send a window to the previous workspace back and forth even if it is empty.
config(options)
general {
layout = dwindle
gaps_in = 4
gaps_out = 8
gaps_workspaces = 10
border_size = 1
no_border_on_floating = false
col.active_border = $green $yellow 45deg
col.inactive_border = $inactive
no_focus_fallback = true
resize_on_border = true
hover_icon_on_border = true
# snap {
# enabled = true
# window_gap = 100
# monitor_gap = 100
# respect_gaps = true
input {
kb_layout = latam
kb_model = pc105
repeat_delay = 300
repeat_rate = 50
follow_mouse = 1
mouse_refocus = true
accel_profile = flat
sensitivity = 0.1
special_fallthrough = true
touchpad {
tap_button_map = lrm
natural_scroll = true
tap-to-click = true
scroll_factor = 0.20
drag_lock = false
tap-and-drag = true
device {
name = elan06fa:00-04f3:31be-touchpad
sensitivity = 1
scroll_method = 2fg
device {
name = logitech-usb-receiver-mouse
sensitivity = 0
dwindle {
pseudotile = false
preserve_split = true
force_split = 2
smart_split = false
smart_resizing = true
master {
mfact = 0.5
new_status = master
new_on_top = true
orientation = left
inherit_fullscreen = true
# always_keep_position = true
# slave_count_for_center_master = 2
group {
insert_after_current = true
focus_removed_window = true
col.border_active = $green $yellow 45deg
groupbar {
enabled = true
stacked = false
scrolling = true
gradients = true
keep_upper_gap = false
priority = 1
gradient_rounding = 10
round_only_edges = false
indicator_height = 0
height = 16
rounding = 1
gaps_in = 10
gaps_out = 10
col.active = rgba(63b76cff)
col.inactive = rgba(63b76c33)
text_color = rgba(111111ff)
font_family = Jet Brains Mono Nerd Font
font_size = 15
decoration {
# rounding = 0
rounding = 4
active_opacity = 1.0
inactive_opacity = 1.0
fullscreen_opacity = 1.0
dim_special = 0.4
shadow {
enabled = false
blur {
enabled = false
animations {
enabled = true
bezier = curve, 0.0, 0.0, 0.58, 1
animation = windows, 1, 1.0, curve, slide
animation = border, 0, 1, curve
# animation = fade, 1, 2, curve
animation = fade, 0
animation = layers, 1, 2, curve
animation = workspaces, 1, 0.5, curve, slide
animation = specialWorkspace, 1, 0.5, curve, slidevert
binds {
# workspace_back_and_forth = false
workspace_center_on = 0
focus_preferred_method = 0
movefocus_cycles_fullscreen = true
misc {
force_default_wallpaper = 0
disable_hyprland_logo = true
disable_splash_rendering = true
new_window_takes_over_fullscreen = 1
exit_window_retains_fullscreen = true
disable_autoreload = true
animate_manual_resizes = false
initial_workspace_tracking = 1
focus_on_activate = true
enable_swallow = false
swallow_regex = (foot|footclient)
swallow_exception_regex = (wev)
lockdead_screen_delay = 3000
cursor {
hide_on_key_press = false
inactive_timeout = 15
enable_hyprcursor = true
gestures {
workspace_swipe_distance = 300
workspace_swipe_cancel_ratio = 0.3
workspace_swipe_min_speed_to_force = 25
workspace_swipe_create_new = true
workspace_swipe_forever = false
xwayland {
enabled = false
use_nearest_neighbor = true
force_zero_scaling = false
render {
new_render_scheduling = true
send_content_type = false
debug {
disable_logs = false
ecosystem {
no_donation_nag = true
no_update_news = true
Anyway, hope this helps in any way.
