Application: plasmashell (6.7.3)
ApplicationNotResponding [ANR]: false
Qt Version: 6.11.1
Frameworks Version: 6.28.0
Operating System: Linux 7.1.3-arch2-2 x86_64
Windowing System: Wayland
Distribution: "Arch Linux"
DrKonqi: 6.7.3 [CoredumpBackend]
-- Information about the crash:
I dont know what i was doing, i was installing hyprland, and when i went logged in to hyprland i cant do anything, just wallpaper and not a single button there. and then when im back to wayland the whole screen is blackm until now. i can only use alt+F2 to search for an app, beside that noting can be used.
The reporter is unsure if this crash is reproducible.
-- Backtrace:
Application: plasmashell (plasmashell), signal: Segmentation fault
This GDB supports auto-downloading debuginfo from the following URLs:
<https://debuginfod.archlinux.org>
Enable debuginfod for this session? (y or [n]) [answered N; input not from terminal]
Debuginfod has been disabled.
To make this setting permanent, add 'set debuginfod enabled off' to .gdbinit.
warning: Can't open file /memfd:JSGCHeap:QtQml (deleted) during file-backed mapping note processing
warning: Can't open file /memfd:kwin-dmabuf-feedback-table (deleted) during file-backed mapping note processing
[New LWP 1920]
[New LWP 1931]
[New LWP 1923]
[New LWP 1922]
[New LWP 1921]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/usr/lib/libthread_db.so.1".
Core was generated by `/usr/bin/plasmashell --no-respawn'.
Program terminated with signal SIGSEGV, Segmentation fault.
#0 0x00007fb7e5a9981c in ?? () from /usr/lib/libc.so.6
[Current thread is 1 (Thread 0x7fb7df37ec80 (LWP 1920))]
/usr/lib/python3.14/site-packages/sentry_sdk/utils.py:1353: EventletDeprecationWarning:
Eventlet is deprecated. It is currently being maintained in bugfix mode, and
we strongly recommend against using it for new projects.
If you are already using Eventlet, we recommend migrating to a different
framework. For more detail see
https://eventlet.readthedocs.io/en/latest/asyncio/migration.html
from eventlet.patcher import is_monkey_patched # type: ignore
Using eu-unstrip to resolve modules.
add symbol table from file "/usr/lib/libc.so.6"
add symbol table from file "/usr/lib/libKF6Crash.so.6"
add symbol table from file "/usr/lib/libQt6Core.so.6"
add symbol table from file "/usr/lib/libKirigamiPlatform.so.6"
add symbol table from file "/usr/lib/qt6/plugins/kf6/kirigami/platform/KirigamiPlasmaStyle.so"
add symbol table from file "/usr/lib/libQt6Quick.so.6"
add symbol table from file "/usr/lib/libPlasmaQuick.so.7"
add symbol table from file "/usr/bin/plasmashell"
add symbol table from file "/usr/lib/libPlasmaActivities.so.7"
add symbol table from file "/usr/lib/libQt6DBus.so.6"
add symbol table from file "/usr/lib/libQt6Widgets.so.6"
add symbol table from file "/usr/lib/libglib-2.0.so.0"
add symbol table from file "/usr/lib/libQt6WaylandClient.so.6"
[Current thread is 5 (Thread 0x7fb7defff6c0 (LWP 1921))]
Thread 5 (Thread 0x7fb7defff6c0 (LWP 1921)):
#0 0x00007fb7e5a9fff2 in ?? () from /usr/lib/libc.so.6
#1 0x00007fb7e5a9403c in ?? () from /usr/lib/libc.so.6
#2 0x00007fb7e5a94084 in ?? () from /usr/lib/libc.so.6
#3 0x00007fb7e5b0ecb6 in ppoll () from /usr/lib/libc.so.6
#4 0x00007fb7e4c7fedf in ?? () from /usr/lib/libglib-2.0.so.0
#5 0x00007fb7e4c7ffe5 in g_main_context_iteration () from /usr/lib/libglib-2.0.so.0
#6 0x00007fb7e669d0b2 in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib/libQt6Core.so.6
#7 0x00007fb7e6391983 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib/libQt6Core.so.6
#8 0x00007fb7e64b9342 in QThread::exec() () from /usr/lib/libQt6Core.so.6
#9 0x00007fb7e73cc7d1 in ?? () from /usr/lib/libQt6DBus.so.6
#10 0x00007fb7e65784fb in ?? () from /usr/lib/libQt6Core.so.6
#11 0x00007fb7e5a97739 in ?? () from /usr/lib/libc.so.6
#12 0x00007fb7e5b1bedc in ?? () from /usr/lib/libc.so.6
Thread 4 (Thread 0x7fb7de3e26c0 (LWP 1922)):
#2 0x00007fb7e5a94387 in ?? () from /usr/lib/libc.so.6
#3 0x00007fb7e5a96bec in pthread_cond_wait () from /usr/lib/libc.so.6
#4 0x00007fb7e6571441 in QWaitCondition::wait(QMutex*, QDeadlineTimer) () from /usr/lib/libQt6Core.so.6
#5 0x00007fb7e74d0687 in ?? () from /usr/lib/libQt6WaylandClient.so.6
#6 0x00007fb7e65784fb in ?? () from /usr/lib/libQt6Core.so.6
#7 0x00007fb7e5a97739 in ?? () from /usr/lib/libc.so.6
#8 0x00007fb7e5b1bedc in ?? () from /usr/lib/libc.so.6
Thread 3 (Thread 0x7fb7ddbe16c0 (LWP 1923)):
#3 0x00007fb7e5b0e68e in poll () from /usr/lib/libc.so.6
#4 0x00007fb7e74d06e8 in ?? () from /usr/lib/libQt6WaylandClient.so.6
#5 0x00007fb7e65784fb in ?? () from /usr/lib/libQt6Core.so.6
#6 0x00007fb7e5a97739 in ?? () from /usr/lib/libc.so.6
#7 0x00007fb7e5b1bedc in ?? () from /usr/lib/libc.so.6
Thread 2 (Thread 0x7fb7d49ff6c0 (LWP 1931)):
#9 0x00007fb7e6578595 in ?? () from /usr/lib/libQt6Core.so.6
#10 0x00007fb7e5a97739 in ?? () from /usr/lib/libc.so.6
#11 0x00007fb7e5b1bedc in ?? () from /usr/lib/libc.so.6
Thread 1 (Thread 0x7fb7df37ec80 (LWP 1920)):
[KCrash Handler]
#4 0x00007fb7e6383514 in QCoreApplication::notifyInternal2(QObject*, QEvent*) () from /usr/lib/libQt6Core.so.6
#5 0x00007fb7d56d5a0c in ?? () from /usr/lib/libKirigamiPlatform.so.6
#6 0x00007fb7d56d3d4b in Kirigami::Platform::PlatformTheme::setTextColor(QColor const&) () from /usr/lib/libKirigamiPlatform.so.6
#7 0x00007fb7d40069fe in ?? () from /usr/lib/qt6/plugins/kf6/kirigami/platform/KirigamiPlasmaStyle.so
#8 0x00007fb7e63f081b in ?? () from /usr/lib/libQt6Core.so.6
#9 0x00007fb7e7d8391b in QQuickItem::itemChange(QQuickItem::ItemChange, QQuickItem::ItemChangeData const&) () from /usr/lib/libQt6Quick.so.6
#10 0x00007fb7e7d7f907 in QQuickItemPrivate::refWindow(QQuickWindow*) () from /usr/lib/libQt6Quick.so.6
#11 0x00007fb7e7d7f8ca in QQuickItemPrivate::refWindow(QQuickWindow*) () from /usr/lib/libQt6Quick.so.6
#12 0x00007fb7e7d7f8ca in QQuickItemPrivate::refWindow(QQuickWindow*) () from /usr/lib/libQt6Quick.so.6
#13 0x00007fb7e7d7f8ca in QQuickItemPrivate::refWindow(QQuickWindow*) () from /usr/lib/libQt6Quick.so.6
#14 0x00007fb7e7d8001a in QQuickItem::setParentItem(QQuickItem*) () from /usr/lib/libQt6Quick.so.6
#15 0x00007fb7e917c4d9 in ?? () from /usr/lib/libPlasmaQuick.so.7
#16 0x0000561930329cbb in ?? ()
#17 0x000056193032b7a5 in ?? ()
#18 0x00007fb7e63f081b in ?? () from /usr/lib/libQt6Core.so.6
#19 0x00007fb7e847a78a in KActivities::Consumer::serviceStatusChanged(KActivities::Consumer::ServiceStatus) () from /usr/lib/libPlasmaActivities.so.7
#20 0x00007fb7e63f081b in ?? () from /usr/lib/libQt6Core.so.6
#21 0x00007fb7e848f1c8 in ?? () from /usr/lib/libPlasmaActivities.so.7
#22 0x00007fb7e8492c3c in ?? () from /usr/lib/libPlasmaActivities.so.7
#23 0x00007fb7e63f0a59 in ?? () from /usr/lib/libQt6Core.so.6
#24 0x00007fb7e742af41 in ?? () from /usr/lib/libQt6DBus.so.6
#25 0x00007fb7e63e7d46 in QObject::event(QEvent*) () from /usr/lib/libQt6Core.so.6
#26 0x00007fb7e870411f in QApplicationPrivate::notify_helper(QObject*, QEvent*) () from /usr/lib/libQt6Widgets.so.6
#27 0x00007fb7e6383658 in QCoreApplication::notifyInternal2(QObject*, QEvent*) () from /usr/lib/libQt6Core.so.6
#28 0x00007fb7e6383a61 in QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*) () from /usr/lib/libQt6Core.so.6
#29 0x00007fb7e669fc98 in ?? () from /usr/lib/libQt6Core.so.6
#30 0x00007fb7e4c7dbfd in ?? () from /usr/lib/libglib-2.0.so.0
#31 0x00007fb7e4c7fe57 in ?? () from /usr/lib/libglib-2.0.so.0
#32 0x00007fb7e4c7ffe5 in g_main_context_iteration () from /usr/lib/libglib-2.0.so.0
#33 0x00007fb7e669d0b2 in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib/libQt6Core.so.6
#34 0x00007fb7e6391983 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib/libQt6Core.so.6
#35 0x00007fb7e6386eaa in QCoreApplication::exec() () from /usr/lib/libQt6Core.so.6
#36 0x00005619302ed5cf in ?? ()
#37 0x00007fb7e5a27741 in ?? () from /usr/lib/libc.so.6
#38 0x00007fb7e5a27879 in __libc_start_main () from /usr/lib/libc.so.6
#39 0x00005619302eddd5 in ?? ()
Reported using DrKonqi
you can report plasma bugs to plasma developers
