Need help with hyprpaper
When I start hyperpaper it outputs…
Error in config:
Config error in file /home/moongoat/.config/hypr/hyprpaper.conf at line 6: config option <wallpaper:monitor> does not exist.
It also outputs the lines…
[WARN] Monitor DP-2 does not have a target! A wallpaper will not be created.
[WARN] Monitor DP-3 does not have a target! A wallpaper will not be created.
[WARN] Monitor DP-1 does not have a target! A wallpaper will not be created.
Anyone know what the issue is?
Hyprland 0.52.2 built from branch v0.52.2 at commit 386376400119dd46a767c9f8c8791fd22c7b6e61 clean ([gha] Nix: update inputs).
Date: Wed Dec 3 22:59:30 2025
Tag: v0.52.2, commits: 6581
Hyprgraphics: built against 0.4.0, system has 0.4.0
Hyprutils: built against 0.10.4, system has 0.10.4
Hyprlang: built against 0.6.7, system has 0.6.7
Full output of hyprpaper
[LOG] Welcome to hyprpaper!
built from commit  ()
[LOG] Cleaned old hyprpaper preloads (2), removing 34.6MB
Error in config:
[LOG] Preloaded target /usr/share/wallpapers/cachyos-wallpapers/DarkStreaks.png in 4.67ms -> Pixel size: [960, 540]
[LOG] Buffer created for target /usr/share/wallpapers/cachyos-wallpapers/DarkStreaks.png, Shared Memory usage: 14.7MB
[LOG] Buffer created for target /usr/share/wallpapers/cachyos-wallpapers/DarkStreaks.png, Shared Memory usage: 19.8MB
[LOG] Total SM usage for all buffers: 34.6MB
[LOG] hyprpaper socket started at /run/user/1000/hypr/386376400119dd46a767c9f8c8791fd22c7b6e61_1764971029_623395502/.hyprpaper.sock (fd: 4)
My hyprpaper.conf
preload = /usr/share/wallpapers/cachyos-wallpapers/DarkStreaks.png
wallpaper {
    monitor = DP-1
    path = /usr/share/wallpapers/cachyos-wallpapers/DarkStreaks.png
    fit_mode = cover    # optional { contain | [cover] | tile | fill }
wallpaper {
    monitor = DP-2
wallpaper {
    monitor = DP-3
Also: Is preload not required anymore? I noticed all mentions of it are not present in the current version wiki.
Thanks
There have been changes to the syntax as part of the move to hyprtoolkit, but those changes are not in a release yet. Wiki is versioned, go back to 0.52.
Of course. How silly of me. Thank you, Vaxry. Looking forward to the new release. I much prefer the new syntax.
