Monitor switching to HDR on launch
Hyprland 0.54.2 built from branch v0.54.2 at commit 59f9f2688ac508a0584d1462151195a6c4992f99 clean (version: bump to 0.54.2).
Setup:
GPU: NVIDIA (proprietary drivers, Wayland)
Compositor: Hyprland (wlroots-based)
Display Manager: SDDM
Monitor: Samsung ViewFinity S70A (HDR10)
Issue:
My system boots into HDR, but Hyprland is set to and reports srgb. The result is that everything looks blown out/oversaturated because SDR content is being shown while the monitor is in HDR mode.
If I run hyprctl monitors, it still shows srgb, so Hyprland thinks everything is correct, but the monitor itself is clearly in HDR. The only ways I’ve found to fix it are:
Manually switching cm to hdredid and back to srgb in the config, or
Playing a YouTube video in fullscreen (Chromium-based browser)
After doing either of those, the display switches back to SDR and everything looks normal, but the issue comes back every time I reboot.
I’ve tried pretty much everything I can think of:
  • Forcing 8-bit / 10-bit formats
  • Forcing modesets (changing resolution/refresh rate/scale)
  • Reloading Hyprland config
  • Forcing SDR via env vars (WLR_DRM_FORCE_FORMAT, disabling atomic, etc.)
  • Disabling HDR in SDDM/KWin (even forcing SDDM to X11)
  • Startup scripts toggling HDR → SDR
None of these actually disable HDR on startup, the scrips did make it flash as if it was changing states but then it still went to HDR.
At this point the only “working” solution is launching a fullscreen browser video on login, which seems ridiculous.
I’ll also note that this doesnt happen in KDE, that switches over to srgb perfectly fine its only an issue on hyprland.
Has anyone ran into this or found a proper way to force SDR on startup with NVIDIA + Hyprland?
UPDATE:
I’ve found somewhat of a workaround, turns out fullscreening any chromium browser will trigger my monitor to switch modes its not only youtube videos, so I made a minimal chromium start on launch and then close to trigger it, heres the line i added:
exec-once = bash -c “/usr/bin/chromium --ozone-platform=wayland --kiosk about:blank --disable-gpu-sandbox --disable-extensions --disable-infobars --no-first-run --no-default-browser-check &
while ! hyprctl clients | grep -q chromium; do sleep 0.2; done;
sleep 1;
pkill chromium”
My monitor does still start in HDR and chromium takes a few seconds to launch but after that it fixes it. You can use a different browser i just figured chromium would be the most lightweight one as I need it to launch as quickly as possible. If any devs are reading this though auto-switching to SDR should definetly be something hyprland does by default no need for launching browsers, KDE and every other DE I’ve used does this without issue.
I’m interesed about the response of this question
I’ve added an update to my post with my solution, its just a hacky workaround the real solution would have to be added into hyprland, hopefully they do that at some point.
I’m experiencing a strange issue with Hyprland on NVIDIA, and I’m not sure whether it’s a Hyprland bug or a monitor compatibility issue.
My monitor is an LG 27GL650F connected via DisplayPort to an NVIDIA GeForce RTX 3070 Ti.
When I’m using Hyprland, my monitor’s OSD always reports “HDR ON”, even though Hyprland appears to be rendering in SDR. Running `hyprctl monitors all` reports SDR output (XRGB8888 / sRGB), and HDR doesn’t appear to be enabled from the OS side.
If I boot into KDE Plasma on the same machine, using the same cable and monitor, the OSD correctly shows “HDR OFF”.
So the behavior is:
• Hyprland → Monitor OSD shows HDR ON
• KDE Plasma → Monitor OSD shows HDR OFF
I’m trying to understand whether Hyprland is sending HDR metadata or some color management information that causes the monitor to switch to HDR mode even though rendering is SDR.
Is there any way to completely disable HDR output or prevent Hyprland from advertising HDR capabilities to the monitor?
Hardware:
- GPU: NVIDIA GeForce RTX 3070 Ti
- NVIDIA Driver: 610.43.03
- Monitor: LG 27GL650F(144Hz, DisplayPort)
- OS: CachyOS
- Desktop: Hyprland
Any help would be greatly appreciated.
