Monitor reporting 18 bit
Whenever my monitor turns on, it reports the signal being 3440x1440 100Hz 18bit
The first two are correct, but why is it saying 18bit and not 24?
Monitor DP-1 (ID 1):
	[email protected] at 1920x0
	description: Dell Inc. DELL P3425WE 1Q8NY54
	make: Dell Inc.
	model: DELL P3425WE
	physical size (mm): 800x330
	serial: 1Q8NY54
	active workspace: 2 (2)
	special workspace: 0 ()
	reserved: 0 33 0 0
	scale: 1.00
	transform: 0
	focused: yes
	dpmsStatus: 1
	vrr: false
	solitary: 0
	activelyTearing: false
	tearingBlockedBy: next frame is not torn,user settings,missing candidate
	directScanoutTo: 0
	directScanoutBlockedBy: windowed mode,missing candidate
	disabled: false
	currentFormat: XRGB8888
	mirrorOf: none
	availableModes: [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected]
	colorManagementPreset: srgb
	sdrBrightness: 1.00
	sdrSaturation: 1.00
	sdrMinLuminance: 0.20
	sdrMaxLuminance: 80
where is the 18 cuz I cant see it
On the transparent popup window that appears on the monitor when turned on, where it reports what it’s getting. Can’t screenshot that, but I can take a picture if you don’t believe me :P
