$mainMod ALT bind stopped working
Hyprland 0.54.3 built from branch v0.54.3 at commit 521ece463c4a9d3d128670688a34756805a4328f clean (version: bump to 0.54.3).
Date: Fri Mar 27 18:17:50 2026
Tag: v0.54.3, commits: 7014
Hyprutils: built against 0.13.0, system has 0.13.0
Version ABI string: 521ece463c4a9d3d128670688a34756805a4328f_aq_0.11_hu_0.13_hg_0.5_hc_0.1_hlg_0.6
I noticed one of my keybinds wasn’t working anymore as it used to. I don’t know whether it has anything to do with the upcoming Lua switch, but I did not change anything in my config and my keyboard is working and in all the correct modes. I also tried the command of the keybind to be sure that that still works as it is supposed to, and it does.
The line that configures the keybind I’m trying is this:
bind = $mainMod ALT, Print, exec, grim -g “$(slurp)” $(xdg-user-dir PICTURES)/Screenshots/$(date +‘%Y%m%d_%Hh%Mm%Ss_grim.png’)
Instead it runs this keybind (which didn’t happen before):
bind = ALT, Print, exec, grim $(xdg-user-dir PICTURES)/Screenshots/$(date +‘%Y%m%d_%Hh%Mm%Ss_grim.png’)
It feels like the $mainMod + ALT combination is not being detected?
I don’t know whether this is a bug or something of my doing, I’m a bit confused. And it also seems that Hyprlang should still be supported so that wouldn’t be it you’d think…
Sounds to me like either a typo with $mainMod, or it’s not set to anything.
hyprlang variables are just simple string substitution.
That bug will be fixed today
No, this was not the issue, I was sure of that.
I don’t know whether the it was indeed ‘fixed’, but I got it working now again.
My keyboard doesn’t have a dedicated Print key, it is a hardware enabled keybind enabled by Fn+RightShift.
Apparently I need to press $mainMod first, then ALT+Fn simultaneously, and lastly RightShift.
For some reason $mainMod –> ALT –> Fn+RShift and $mainMod + ALT –> Fn+RShift doesn’t work, even though that’s what I would expect.
Thanks for the help though!
Edit:
I experimented a little more. I changed the config into this:
bind = $mainModALT, Print, exec, grim -g “$(slurp)” $(xdg-user-dir PICTURES)/Screenshots/$(date +‘%Y%m%d_%Hh%Mm%Ss_grim.png’)
removing the space between $mainMod and ALT. Now it works much more consistent and intuitive: $mainMod –> ALT –> Fn+RShift is the behavior in that case.
