Keysym combos not working when using F13-20 and Numbers
0.54.1
So I have some lines that are like the following:
bind = $mainMod, F13&1, workspace, 11
bind = $mainMod, F13&2, workspace, 12
Though I can’t get the ..&.. to behave when using Function keys.
Currently nothing happens when using the above configs.
I have checked using wev that the correct keys are being pressed. Also tried using code: instead of F13-F15.
At this point I am kind of stumped, though I haven’t seen anyone else attempting what I am doing using keysyms combos with function keys. So it is possible that what I am trying to do just will not work.
Context on why I am trying to do it this way is I am using a macro pad to select which workspace I am using on a given monitor. So basically I have Mod+(F13-F15)+(1-6) bound to separate buttons. I would have done it by using more modifiers, e.g. using Atl/Ctrl, but I have encounter problems when using specific applications’ keybinds when doing this.
If you want to combine keys you have to use binds and use their keysyms.
I am aware, hence the usage of binds shown in my original message.
Furthermore I know the function keys are working as I have tested without the &1, &2, etc.
should be
binds = SUPER_L, F13&1, workspace, 11
binds = SUPER_L, F13&2, workspace, 12
If F13 are the keysyms.
Okay so with the direction @Ergon gave, I was able to pin down what I was doing wrong.
  • bind =/= binds
    • The letters after the word bind are modifiers, e.g. bindr or binde
  • binds need specifically the Keysyms, which means things like SUPER do not work as they actual Keysym is SUPER_L
    • keysyms are extremely specific, and you should match what the label wev produces for a given key.
I don’t mean to take the solution that @Ergon provided, but I wanted to provide a slightly better explanation for someone possibly making the same mistake I am making.
