Keybinding Inspired from ML4W
Just a quick keybinding adjustment to match ML4W layout. Everything is Mostly the same. Launching Apps is Super + Space.
Add this to “binds.conf” found in ~/.config/hypr/custom.d/regular/
Terminal: Super + Enter
unbind = $mainMod, Q, exec, $terminal
bind = $mainMod, RETURN, exec, $terminal
Close/Quite: Super + Q
unbind = $mainMod, C, killactive,
bind = $mainMod, Q, killactive,
Open Browser: Super + B
bind = $mainMod, B, exec, firefox
Open Apps: Super + Space
unbind = $mainMod, R, exec, $menu
bind = $mainMod, SPACE, exec, $menu
Toggle Floating: Super + T
unbind = $mainMod, V, togglefloating
bind = $mainMod, T, togglefloating
Unbind Exit: Super + M
unbind = $mainMod, M, exit,
Resize Window: Super + Shift + Arrow
bind = $mainMod SHIFT, right, resizeactive, 100 0
bind = $mainMod SHIFT, left, resizeactive, -100 0
bind = $mainMod SHIFT, down, resizeactive, 0 100
bind = $mainMod SHIFT, up, resizeactive, 0 -100
Active Window Switch Placement: Super + K
bind = $mainMod, K, swapsplit
Active Window Move: Super + Alt + Arrow
bind = $mainMod ALT, left, swapwindow, l
bind = $mainMod ALT, right, swapwindow, r
bind = $mainMod ALT, up, swapwindow, u
bind = $mainMod ALT, down, swapwindow, d
Updating to include Toggle all windows on Active workspace and Move all. Rename to “binds.conf” and place in ~/.config/hypr/custom.d/regular/
binds.txt (2.3 KB)
windows on active workspace
