Issue with hyprland-git after system update – missing libdisplay-info.so.2
Hyprland 0.51.1 built from branch  at commit 71a1216abcc7031776630a6d88f105605c4dc1c9  ([gha] Nix: update inputs).
Tag: v0.51.1, commits: 6436
 aquamarine 0.9.4
 hyprutils 0.8.4
 hyprgraphics 0.1.6
Hi, I wanted to share an issue I encountered when using hyprland-git on Arch Linux, in case it helps others.
After a system update, Hyprland failed to start with the following error:
Hyprland: error while loading shared libraries: libdisplay-info.so.2: cannot open shared object file: No such file or directory
The problem was caused by libdisplay-info being updated to libdisplay-info.so.3, while my locally built hyprland-git binary was still linked against .so.2. This led to a broken dependency and the compositor wouldn’t launch.
Steps I took to fix it:
Rebuilt the whole Hyprland git stack (hyprland-git, wlroots-git, hyprutils-git, etc.) with
yay -Syu --devel --timeupdate
→ this aligns all -git packages with the updated libraries.
Later, to avoid frequent breakages, I decided to switch back to the official Hyprland packages from the Arch repos (hyprland, hyprutils, hyprcursor, hyprgraphics, hyprlang, hyprwayland-scanner, etc.).
I had to replace the -git packages step by step, removing blockers like hyprlang-git first, then reinstalling the stable equivalents.
After cleaning up leftover -git and -git-debug packages, Hyprland launched without issues.
Conclusion:
If anyone runs into a similar error with hyprland-git on Arch, the solution is to rebuild all related -git packages after a SONAME bump, or alternatively, switch to the stable repo version to avoid ABI mismatches.
Yes, in general when you build packages from source, the responsibility for maintaining ABI compatibility falls on you, as it’s normally done by the packager, but when you build, well, you’re the packager. :)
This stuff was sitting in staging for the past 5 weeks:
It’s not like that required rebuild was a suprise. Gotta pay attention.
