Hyprpaper is not working due to error of monitor having no target
hyprland 0.56.2 built from branch v0.56.2 at commit efb50993780079460b0cbed1363e2166a2de1d9f clean ([gha] nix: update inputs).
date: wed aug 5 14:13:21 2026
tag: v0.56.2, commits: 7661
libraries:
hyprgraphics: built against 0.5.1, system has 0.5.1
hyprutils: built against 0.14.1, system has 0.14.2
hyprcursor: built against 0.1.13, system has 0.1.13
hyprlang: built against 0.6.8, system has 0.6.8
aquamarine: built against 0.15.0, system has 0.15.0
version abi string: efb50993780079460b0cbed1363e2166a2de1d9f_aq_0.15_hu_0.14_hg_0.5_hc_0.1_hlg_0.6
I am trying to change the wallpaper but i get the same output each time run hyprpaper
[DEBUG]: Welcome to hyprpaper!
built from commit ()
[ERR]: Failed to resolve path ,:/home/user/Downloads/wallpapers: invalid path: No such file or directory
[DEBUG]: Found 1 output(s)
[DEBUG]: Monitor eDP-1 has no target: no wp will be created
this is my config in hypr/hyprland.conf and ‘yes’ i did verify that it is the correct config file with the script that hyprpaper uses
wallpaper {
monitor = eDP-1,
path = /home/user/Downloads/wallpapers
fit_mode = cover
also this is the output for hyprctl hyprpaper wallpaper ‘eDP-1, /home/user/Downloads/wallpapers,cover’
[hw] err: err: 111
error: can’t send: failed to connect to hyprpaper (is it running?)
