Hyprlauncher / Hyprtoolkit color theming
Hyprland 0.55.0 built from branch v0.55.0 at commit af923e30d1d24f1f4a4f5cb8308065173c1d9539 clean (version: bump to 0.55.0).
Date: Sat May 9 13:35:27 2026
Tag: v0.55.0, commits: 7290
Version ABI string: af923e30d1d24f1f4a4f5cb8308065173c1d9539_aq_0.11_hu_0.13_hg_0.5_hc_0.1_hlg_0.6
Hello Hyprworld!
I am trying to get hyprlauncher to match the rest of my color scheme / theme. Reading the wiki page, I see there should be a config file for hyprtoolkit from which it should get it’s theming. i.e ~/.config/hypr/hyprtoolkit.conf
Alas, I do not have this config file, and I couldn’t find it mentioned on github. Would you please point me in the right direction? (Also should it be a .lua file now?)
Create it. $ vim ~/.config/hypr/hyprtoolkit.conf
No.
Alright I have made an empty file ~/.config/hypr/hyprtoolkit.conf. After restarting hyprland, it is still empty.
Do I need to follow the hyprlang guide to create my own config file with the variables defined on the hyprtoolkit wiki page? Through his noodly appendage, all things are possible, but I wanted to check to see if there was a default config I could yoink from somewhere.
Yes. It’s your config. Config how you’d like.
Very nice… first person on any forum to pick up on that and comment. Ramen!
