Hyprland washed output
hyprland 0.54
around systemwide including screenshot & screen recording its comes with washed out on whatever the software is ..
how do I solve this?
looks normal on my end? Washed out usually means bad color management settings.
“looks normal on my end”
really?
let me tell you clealry it only happens with screenrecording or screenshots
in my monitor my end everything looks so fine but when I try to capture the screen it happens
how do I fix this
I have no idea about color management & stuff
What does your monitor config look like, in Hyprland? Also, are you using an HDR monitor by any chance?
And what screenshot/screen recording software are you using?
May be related to:
$ hyprctl monitors
Monitor DP-1 (ID 0):
[email protected] at 0x0
description: Dell Inc. DELL E1916HV 779TP814C4YB
make: Dell Inc.
model: DELL E1916HV
physical size (mm): 410x230
serial: 779TP814C4YB
active workspace: 3 (3)
special workspace: 0 ()
reserved: 0 30 0 0
scale: 1.00
transform: 0
focused: yes
dpmsStatus: 1
vrr: false
solitary: 0
activelyTearing: false
tearingBlockedBy: next frame is not torn,user settings,missing candidate,hw cursor
directScanoutTo: 0
directScanoutBlockedBy: user settings,missing candidate
disabled: false
currentFormat: XRGB8888
mirrorOf: none
availableModes: [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected]
colorManagementPreset: srgb
sdrBrightness: 1.00
sdrSaturation: 1.00
sdrMinLuminance: 0.20
sdrMaxLuminance: 80
wf recorder
screenshot output is fixed
but screen recording washed out issue still remains
