Hyprland 0.53.0 built from branch main at commit e80f705d76d4dbe836e0f57aadea994a624ac63e clean (compositor: guard null view() in getWindowFromSurface ( 13255)).
Date: Sat Feb 14 00:52:15 2026
Tag: v0.53.0-132-ge80f705d, commits: 6888
Version ABI string: e80f705d76d4dbe836e0f57aadea994a624ac63e_aq_0.10_hu_0.11_hg_0.5_hc_0.1_hlg_0.6
Hey guys, I switched from the AUR Hyprland version to the self build Github version quite some time ago (0.52.x), because the hyprpm packages didn’t work with the Arch packages, pulled and updated regularly until my current version. Since then i can’t build Hyprland anymore because of “missing” header files. I’ve tried some steps already (remove build dir and rebuild, remove hyprland git folder and redownload it again, checking dependencies and stuff, following the guide mentioned in this topic but the build fails for me), but I keep crashing at the same errors:
earlier identical errors
In file included from /home/germanikus/GitClones/Hyprland/start/src/helpers/Nix.cpp:3:
/home/germanikus/GitClones/Hyprland/start/src/helpers/Logger.hpp:3:10: fatal error: hyprutils/cli/Logger.hpp: No such file or directory
3 | #include <hyprutils/cli/Logger.hpp>
compilation terminated.
make[4]: *** [start/CMakeFiles/start-hyprland.dir/build.make:93: start/CMakeFiles/start-hyprland.dir/src/helpers/Nix.cpp.o] Fehler 1
/home/germanikus/GitClones/Hyprland/hyprpm/src/core/Manifest.cpp:2:10: fatal error: toml++/toml.hpp: No such file or directory
2 | #include <toml++/toml.hpp>
make[4]: *** [hyprpm/CMakeFiles/hyprpm.dir/build.make:107: hyprpm/CMakeFiles/hyprpm.dir/src/core/Manifest.cpp.o] Fehler 1
make[4]: *** Es wird auf noch nicht beendete Prozesse gewartet …
[ 17%] Building CXX object CMakeFiles/hyprland_lib.dir/cmake_pch.hxx.gch
In file included from /home/germanikus/GitClones/Hyprland/hyprctl/hw-protocols/hyprpaper_core-client.hpp:43,
from /home/germanikus/GitClones/Hyprland/hyprctl/hw-protocols/hyprpaper_core-client.cpp:41:
/home/germanikus/GitClones/Hyprland/hyprctl/hw-protocols/hyprpaper_core-spec.hpp:42:10: fatal error: hyprwire/core/types/MessageMagic.hpp: No such file or directory
42 | #include <hyprwire/core/types/MessageMagic.hpp>
In file included from /home/germanikus/GitClones/Hyprland/hyprctl/src/hyprpaper/Hyprpaper.cpp:2:
/home/germanikus/GitClones/Hyprland/hyprctl/src/hyprpaper/../helpers/Memory.hpp:3:10: fatal error: hyprutils/memory/SharedPtr.hpp: No such file or directory
3 | #include <hyprutils/memory/SharedPtr.hpp>
make[4]: *** [hyprctl/CMakeFiles/hyprctl.dir/build.make:117: hyprctl/CMakeFiles/hyprctl.dir/hw-protocols/hyprpaper_core-client.cpp.o] Fehler 1
make[4]: *** [hyprctl/CMakeFiles/hyprctl.dir/build.make:89: hyprctl/CMakeFiles/hyprctl.dir/src/hyprpaper/Hyprpaper.cpp.o] Fehler 1
In file included from /home/germanikus/GitClones/Hyprland/start/src/main.cpp:5:
/home/germanikus/GitClones/Hyprland/hyprpm/src/core/HyprlandSocket.cpp:9:10: fatal error: hyprutils/memory/Casts.hpp: No such file or directory
9 | #include <hyprutils/memory/Casts.hpp>
make[4]: *** [start/CMakeFiles/start-hyprland.dir/build.make:107: start/CMakeFiles/start-hyprland.dir/src/main.cpp.o] Fehler 1
make[3]: *** [CMakeFiles/Makefile2:1211: start/CMakeFiles/start-hyprland.dir/all] Fehler 2
make[3]: *** Es wird auf noch nicht beendete Prozesse gewartet …
make[4]: *** [hyprpm/CMakeFiles/hyprpm.dir/build.make:93: hyprpm/CMakeFiles/hyprpm.dir/src/core/HyprlandSocket.cpp.o] Fehler 1
/home/germanikus/GitClones/Hyprland/hyprpm/src/core/DataState.cpp:3:10: fatal error: toml++/toml.hpp: No such file or directory
3 | #include <toml++/toml.hpp>
/home/germanikus/GitClones/Hyprland/hyprpm/src/helpers/Sys.cpp:13:10: fatal error: hyprutils/os/Process.hpp: No such file or directory
13 | #include <hyprutils/os/Process.hpp>
make[4]: *** [hyprpm/CMakeFiles/hyprpm.dir/build.make:79: hyprpm/CMakeFiles/hyprpm.dir/src/core/DataState.cpp.o] Fehler 1
make[4]: *** [hyprpm/CMakeFiles/hyprpm.dir/build.make:149: hyprpm/CMakeFiles/hyprpm.dir/src/helpers/Sys.cpp.o] Fehler 1
/home/germanikus/GitClones/Hyprland/hyprpm/src/progress/CProgressBar.cpp:12:10: fatal error: hyprutils/memory/Casts.hpp: No such file or directory
12 | #include <hyprutils/memory/Casts.hpp>
make[4]: *** [hyprpm/CMakeFiles/hyprpm.dir/build.make:177: hyprpm/CMakeFiles/hyprpm.dir/src/progress/CProgressBar.cpp.o] Fehler 1
/home/germanikus/GitClones/Hyprland/hyprpm/src/main.cpp:11:10: fatal error: hyprutils/utils/ScopeGuard.hpp: No such file or directory
11 | #include <hyprutils/utils/ScopeGuard.hpp>
make[4]: *** [hyprpm/CMakeFiles/hyprpm.dir/build.make:163: hyprpm/CMakeFiles/hyprpm.dir/src/main.cpp.o] Fehler 1
/home/germanikus/GitClones/Hyprland/hyprpm/src/core/PluginManager.cpp:25:10: fatal error: toml++/toml.hpp: No such file or directory
25 | #include <toml++/toml.hpp>
make[4]: *** [hyprpm/CMakeFiles/hyprpm.dir/build.make:135: hyprpm/CMakeFiles/hyprpm.dir/src/core/PluginManager.cpp.o] Fehler 1
/home/germanikus/GitClones/Hyprland/hyprctl/src/main.cpp:28:10: fatal error: hyprutils/string/String.hpp: No such file or directory
28 | #include <hyprutils/string/String.hpp>
make[4]: *** [hyprctl/CMakeFiles/hyprctl.dir/build.make:103: hyprctl/CMakeFiles/hyprctl.dir/src/main.cpp.o] Fehler 1
make[3]: *** [CMakeFiles/Makefile2:1179: hyprctl/CMakeFiles/hyprctl.dir/all] Fehler 2
make[3]: *** [CMakeFiles/Makefile2:1243: hyprpm/CMakeFiles/hyprpm.dir/all] Fehler 2
[ 17%] Building CXX object CMakeFiles/hyprland_lib.dir/src/config/ConfigValue.cpp.o
[ 25%] Building CXX object CMakeFiles/hyprland_lib.dir/src/desktop/state/FocusState.cpp.o
In file included from /home/germanikus/GitClones/Hyprland/src/config/ConfigWatcher.hpp:2,
from /home/germanikus/GitClones/Hyprland/src/config/ConfigWatcher.cpp:1:
/home/germanikus/GitClones/Hyprland/src/config/../helpers/memory/Memory.hpp:3:10: fatal error: hyprutils/memory/WeakPtr.hpp: No such file or directory
3 | #include <hyprutils/memory/WeakPtr.hpp>
In file included from /home/germanikus/GitClones/Hyprland/src/config/ConfigValue.cpp:1:
/home/germanikus/GitClones/Hyprland/src/config/ConfigValue.hpp:5:10: fatal error: hyprlang.hpp: No such file or directory
5 | #include <hyprlang.hpp>
In file included from /home/germanikus/GitClones/Hyprland/src/desktop/Workspace.hpp:3,
from /home/germanikus/GitClones/Hyprland/src/desktop/Workspace.cpp:1:
/home/germanikus/GitClones/Hyprland/src/desktop/../helpers/AnimatedVariable.hpp:3:10: fatal error: hyprutils/animation/AnimatedVariable.hpp: No such file or directory
3 | #include <hyprutils/animation/AnimatedVariable.hpp>
make[4]: *** [CMakeFiles/hyprland_lib.dir/build.make:564: CMakeFiles/hyprland_lib.dir/src/config/ConfigWatcher.cpp.o] Fehler 1
In file included from /home/germanikus/GitClones/Hyprland/src/debug/log/Logger.cpp:1:
/home/germanikus/GitClones/Hyprland/src/debug/log/Logger.hpp:3:10: fatal error: hyprutils/cli/Logger.hpp: No such file or directory
In file included from /home/germanikus/GitClones/Hyprland/src/desktop/reserved/ReservedArea.hpp:3,
from /home/germanikus/GitClones/Hyprland/src/desktop/reserved/ReservedArea.cpp:1:
/home/germanikus/GitClones/Hyprland/src/desktop/reserved/../../helpers/math/Math.hpp:3:10: fatal error: wayland-server-protocol.h: No such file or directory
3 | #include <wayland-server-protocol.h>
In file included from /home/germanikus/GitClones/Hyprland/src/desktop/rule/matchEngine/../../DesktopTypes.hpp:2,
from /home/germanikus/GitClones/Hyprland/src/desktop/rule/matchEngine/MatchEngine.hpp:3,
from /home/germanikus/GitClones/Hyprland/src/desktop/rule/Rule.hpp:3,
from /home/germanikus/GitClones/Hyprland/src/desktop/rule/Engine.hpp:3,
from /home/germanikus/GitClones/Hyprland/src/desktop/rule/Engine.cpp:1:
/home/germanikus/GitClones/Hyprland/src/desktop/rule/matchEngine/../../../helpers/memory/Memory.hpp:3:10: fatal error: hyprutils/memory/WeakPtr.hpp: No such file or directory
In file included from /home/germanikus/GitClones/Hyprland/src/defines.hpp:3,
from /home/germanikus/GitClones/Hyprland/src/debug/crash/SignalSafe.hpp:3,
from /home/germanikus/GitClones/Hyprland/src/debug/crash/SignalSafe.cpp:1:
/home/germanikus/GitClones/Hyprland/src/includes.hpp:10:10: fatal error: libinput.h: No such file or directory
10 | #include <libinput.h>
make[4]: *** [CMakeFiles/hyprland_lib.dir/build.make:660: CMakeFiles/hyprland_lib.dir/src/debug/log/Logger.cpp.o] Fehler 1
make[4]: *** [CMakeFiles/hyprland_lib.dir/build.make:548: CMakeFiles/hyprland_lib.dir/src/config/ConfigValue.cpp.o] Fehler 1
make[4]: *** [CMakeFiles/hyprland_lib.dir/build.make:676: CMakeFiles/hyprland_lib.dir/src/desktop/Workspace.cpp.o] Fehler 1
In file included from /home/germanikus/GitClones/Hyprland/src/desktop/history/../DesktopTypes.hpp:2,
from /home/germanikus/GitClones/Hyprland/src/desktop/history/WorkspaceHistoryTracker.hpp:3,
from /home/germanikus/GitClones/Hyprland/src/desktop/history/WorkspaceHistoryTracker.cpp:1:
/home/germanikus/GitClones/Hyprland/src/desktop/history/../../helpers/memory/Memory.hpp:3:10: fatal error: hyprutils/memory/WeakPtr.hpp: No such file or directory
make[4]: *** [CMakeFiles/hyprland_lib.dir/build.make:724: CMakeFiles/hyprland_lib.dir/src/desktop/reserved/ReservedArea.cpp.o] Fehler 1
make[4]: *** [CMakeFiles/hyprland_lib.dir/build.make:740: CMakeFiles/hyprland_lib.dir/src/desktop/rule/Engine.cpp.o] Fehler 1
In file included from /home/germanikus/GitClones/Hyprland/src/debug/HyprCtl.hpp:4,
from /home/germanikus/GitClones/Hyprland/src/debug/HyprCtl.cpp:1:
/home/germanikus/GitClones/Hyprland/src/debug/../helpers/MiscFunctions.hpp:4:10: fatal error: wayland-server.h: No such file or directory
4 | #include <wayland-server.h>
make[4]: *** [CMakeFiles/hyprland_lib.dir/build.make:644: CMakeFiles/hyprland_lib.dir/src/debug/crash/SignalSafe.cpp.o] Fehler 1
In file included from /home/germanikus/GitClones/Hyprland/src/desktop/rule/layerRule/../../DesktopTypes.hpp:2,
from /home/germanikus/GitClones/Hyprland/src/desktop/rule/layerRule/LayerRuleApplicator.hpp:3,
from /home/germanikus/GitClones/Hyprland/src/desktop/rule/layerRule/LayerRuleApplicator.cpp:1:
/home/germanikus/GitClones/Hyprland/src/desktop/rule/layerRule/../../../helpers/memory/Memory.hpp:3:10: fatal error: hyprutils/memory/WeakPtr.hpp: No such file or directory
[ 25%] Building CXX object CMakeFiles/hyprland_lib.dir/src/desktop/view/Group.cpp.o
[ 26%] Building CXX object CMakeFiles/hyprland_lib.dir/src/desktop/view/LayerSurface.cpp.o
from /home/germanikus/GitClones/Hyprland/src/desktop/rule/Rule.cpp:1:
make[4]: *** [CMakeFiles/hyprland_lib.dir/build.make:708: CMakeFiles/hyprland_lib.dir/src/desktop/history/WorkspaceHistoryTracker.cpp.o] Fehler 1
make[4]: *** [CMakeFiles/hyprland_lib.dir/build.make:580: CMakeFiles/hyprland_lib.dir/src/debug/HyprCtl.cpp.o] Fehler 1
In file included from /home/germanikus/GitClones/Hyprland/src/desktop/rule/layerRule/../matchEngine/../../DesktopTypes.hpp:2,
from /home/germanikus/GitClones/Hyprland/src/desktop/rule/layerRule/../matchEngine/MatchEngine.hpp:3,
from /home/germanikus/GitClones/Hyprland/src/desktop/rule/layerRule/../Rule.hpp:3,
from /home/germanikus/GitClones/Hyprland/src/desktop/rule/layerRule/LayerRule.hpp:3,
from /home/germanikus/GitClones/Hyprland/src/desktop/rule/layerRule/LayerRule.cpp:1:
/home/germanikus/GitClones/Hyprland/src/desktop/rule/layerRule/../matchEngine/../../../helpers/memory/Memory.hpp:3:10: fatal error: hyprutils/memory/WeakPtr.hpp: No such file or directory
make[4]: *** [CMakeFiles/hyprland_lib.dir/build.make:788: CMakeFiles/hyprland_lib.dir/src/desktop/rule/layerRule/LayerRuleApplicator.cpp.o] Fehler 1
from /home/germanikus/GitClones/Hyprland/src/desktop/rule/matchEngine/TagMatchEngine.hpp:3,
from /home/germanikus/GitClones/Hyprland/src/desktop/rule/matchEngine/TagMatchEngine.cpp:1:
from /home/germanikus/GitClones/Hyprland/src/desktop/rule/matchEngine/BoolMatchEngine.hpp:3,
from /home/germanikus/GitClones/Hyprland/src/desktop/rule/matchEngine/BoolMatchEngine.cpp:1:
make[4]: *** [CMakeFiles/hyprland_lib.dir/build.make:756: CMakeFiles/hyprland_lib.dir/src/desktop/rule/Rule.cpp.o] Fehler 1
from /home/germanikus/GitClones/Hyprland/src/desktop/rule/matchEngine/IntMatchEngine.hpp:3,
from /home/germanikus/GitClones/Hyprland/src/desktop/rule/matchEngine/IntMatchEngine.cpp:1:
from /home/germanikus/GitClones/Hyprland/src/desktop/history/WindowHistoryTracker.hpp:3,
from /home/germanikus/GitClones/Hyprland/src/desktop/history/WindowHistoryTracker.cpp:1:
make[4]: *** [CMakeFiles/hyprland_lib.dir/build.make:772: CMakeFiles/hyprland_lib.dir/src/desktop/rule/layerRule/LayerRule.cpp.o] Fehler 1
make[4]: *** [CMakeFiles/hyprland_lib.dir/build.make:884: CMakeFiles/hyprland_lib.dir/src/desktop/rule/matchEngine/TagMatchEngine.cpp.o] Fehler 1
make[4]: *** [CMakeFiles/hyprland_lib.dir/build.make:820: CMakeFiles/hyprland_lib.dir/src/desktop/rule/matchEngine/BoolMatchEngine.cpp.o] Fehler 1
In file included from /home/germanikus/GitClones/Hyprland/src/desktop/rule/windowRule/../matchEngine/../../DesktopTypes.hpp:2,
from /home/germanikus/GitClones/Hyprland/src/desktop/rule/windowRule/../matchEngine/MatchEngine.hpp:3,
from /home/germanikus/GitClones/Hyprland/src/desktop/rule/windowRule/../Rule.hpp:3,
from /home/germanikus/GitClones/Hyprland/src/desktop/rule/windowRule/WindowRule.hpp:3,
from /home/germanikus/GitClones/Hyprland/src/desktop/rule/windowRule/WindowRule.cpp:1:
/home/germanikus/GitClones/Hyprland/src/desktop/rule/windowRule/../matchEngine/../../../helpers/memory/Memory.hpp:3:10: fatal error: hyprutils/memory/WeakPtr.hpp: No such file or directory
from /home/germanikus/GitClones/Hyprland/src/desktop/rule/matchEngine/RegexMatchEngine.hpp:3,
from /home/germanikus/GitClones/Hyprland/src/desktop/rule/matchEngine/RegexMatchEngine.cpp:1:
make[4]: *** [CMakeFiles/hyprland_lib.dir/build.make:836: CMakeFiles/hyprland_lib.dir/src/desktop/rule/matchEngine/IntMatchEngine.cpp.o] Fehler 1
make[4]: *** [CMakeFiles/hyprland_lib.dir/build.make:692: CMakeFiles/hyprland_lib.dir/src/desktop/history/WindowHistoryTracker.cpp.o] Fehler 1
In file included from /home/germanikus/GitClones/Hyprland/src/desktop/rule/layerRule/LayerRuleEffectContainer.hpp:4,
from /home/germanikus/GitClones/Hyprland/src/desktop/rule/layerRule/LayerRuleEffectContainer.cpp:1:
make[4]: *** [CMakeFiles/hyprland_lib.dir/build.make:868: CMakeFiles/hyprland_lib.dir/src/desktop/rule/matchEngine/RegexMatchEngine.cpp.o] Fehler 1
make[4]: *** [CMakeFiles/hyprland_lib.dir/build.make:916: CMakeFiles/hyprland_lib.dir/src/desktop/rule/windowRule/WindowRule.cpp.o] Fehler 1
In file included from /home/germanikus/GitClones/Hyprland/src/desktop/state/../DesktopTypes.hpp:2,
from /home/germanikus/GitClones/Hyprland/src/desktop/state/FocusState.hpp:3,
from /home/germanikus/GitClones/Hyprland/src/desktop/state/FocusState.cpp:1:
/home/germanikus/GitClones/Hyprland/src/desktop/state/../../helpers/memory/Memory.hpp:3:10: fatal error: hyprutils/memory/WeakPtr.hpp: No such file or directory
from /home/germanikus/GitClones/Hyprland/src/desktop/rule/matchEngine/WorkspaceMatchEngine.hpp:3,
from /home/germanikus/GitClones/Hyprland/src/desktop/rule/matchEngine/WorkspaceMatchEngine.cpp:1:
make[4]: *** [CMakeFiles/hyprland_lib.dir/build.make:804: CMakeFiles/hyprland_lib.dir/src/desktop/rule/layerRule/LayerRuleEffectContainer.cpp.o] Fehler 1
from /home/germanikus/GitClones/Hyprland/src/desktop/rule/matchEngine/MatchEngine.cpp:1:
make[4]: *** [CMakeFiles/hyprland_lib.dir/build.make:964: CMakeFiles/hyprland_lib.dir/src/desktop/state/FocusState.cpp.o] Fehler 1
make[4]: *** [CMakeFiles/hyprland_lib.dir/build.make:900: CMakeFiles/hyprland_lib.dir/src/desktop/rule/matchEngine/WorkspaceMatchEngine.cpp.o] Fehler 1
In file included from /home/germanikus/GitClones/Hyprland/src/desktop/rule/windowRule/WindowRuleEffectContainer.hpp:4,
from /home/germanikus/GitClones/Hyprland/src/desktop/rule/windowRule/WindowRuleEffectContainer.cpp:1:
/home/germanikus/GitClones/Hyprland/src/desktop/rule/windowRule/../../../helpers/memory/Memory.hpp:3:10: fatal error: hyprutils/memory/WeakPtr.hpp: No such file or directory
make[4]: *** [CMakeFiles/hyprland_lib.dir/build.make:852: CMakeFiles/hyprland_lib.dir/src/desktop/rule/matchEngine/MatchEngine.cpp.o] Fehler 1
In file included from /home/germanikus/GitClones/Hyprland/src/debug/crash/CrashReporter.cpp:9:
/home/germanikus/GitClones/Hyprland/src/debug/crash/../../helpers/MiscFunctions.hpp:4:10: fatal error: wayland-server.h: No such file or directory
make[4]: *** [CMakeFiles/hyprland_lib.dir/build.make:948: CMakeFiles/hyprland_lib.dir/src/desktop/rule/windowRule/WindowRuleEffectContainer.cpp.o] Fehler 1
from /home/germanikus/GitClones/Hyprland/src/desktop/rule/windowRule/WindowRuleApplicator.hpp:6,
from /home/germanikus/GitClones/Hyprland/src/desktop/rule/windowRule/WindowRuleApplicator.cpp:1:
make[4]: *** [CMakeFiles/hyprland_lib.dir/build.make:628: CMakeFiles/hyprland_lib.dir/src/debug/crash/CrashReporter.cpp.o] Fehler 1
In file included from /home/germanikus/GitClones/Hyprland/src/desktop/view/../../defines.hpp:3,
from /home/germanikus/GitClones/Hyprland/src/desktop/view/WLSurface.hpp:3,
from /home/germanikus/GitClones/Hyprland/src/desktop/view/View.hpp:3,
from /home/germanikus/GitClones/Hyprland/src/desktop/view/GlobalViewMethods.hpp:3,
from /home/germanikus/GitClones/Hyprland/src/desktop/view/GlobalViewMethods.cpp:1:
/home/germanikus/GitClones/Hyprland/src/desktop/view/../../includes.hpp:10:10: fatal error: libinput.h: No such file or directory
make[4]: *** [CMakeFiles/hyprland_lib.dir/build.make:932: CMakeFiles/hyprland_lib.dir/src/desktop/rule/windowRule/WindowRuleApplicator.cpp.o] Fehler 1
make[4]: *** [CMakeFiles/hyprland_lib.dir/build.make:980: CMakeFiles/hyprland_lib.dir/src/desktop/view/GlobalViewMethods.cpp.o] Fehler 1
from /home/germanikus/GitClones/Hyprland/src/desktop/view/LayerSurface.hpp:4,
from /home/germanikus/GitClones/Hyprland/src/desktop/view/LayerSurface.cpp:1:
In file included from /home/germanikus/GitClones/Hyprland/src/desktop/view/../DesktopTypes.hpp:2,
from /home/germanikus/GitClones/Hyprland/src/desktop/view/Group.hpp:3,
from /home/germanikus/GitClones/Hyprland/src/desktop/view/Group.cpp:1:
/home/germanikus/GitClones/Hyprland/src/desktop/view/../../helpers/memory/Memory.hpp:3:10: fatal error: hyprutils/memory/WeakPtr.hpp: No such file or directory
make[4]: *** [CMakeFiles/hyprland_lib.dir/build.make:1012: CMakeFiles/hyprland_lib.dir/src/desktop/view/LayerSurface.cpp.o] Fehler 1
make[4]: *** [CMakeFiles/hyprland_lib.dir/build.make:996: CMakeFiles/hyprland_lib.dir/src/desktop/view/Group.cpp.o] Fehler 1
In file included from /home/germanikus/GitClones/Hyprland/src/config/ConfigManager.cpp:3:
/home/germanikus/GitClones/Hyprland/src/config/ConfigManager.hpp:3:10: fatal error: hyprutils/animation/AnimationConfig.hpp: No such file or directory
3 | #include <hyprutils/animation/AnimationConfig.hpp>
In file included from /home/germanikus/GitClones/Hyprland/src/managers/../defines.hpp:3,
from /home/germanikus/GitClones/Hyprland/src/managers/XWaylandManager.hpp:3,
from /home/germanikus/GitClones/Hyprland/src/Compositor.hpp:8,
from /home/germanikus/GitClones/Hyprland/src/Compositor.cpp:4:
/home/germanikus/GitClones/Hyprland/src/managers/../includes.hpp:10:10: fatal error: libinput.h: No such file or directory
make[4]: *** [CMakeFiles/hyprland_lib.dir/build.make:516: CMakeFiles/hyprland_lib.dir/src/Compositor.cpp.o] Fehler 1
make[4]: *** [CMakeFiles/hyprland_lib.dir/build.make:532: CMakeFiles/hyprland_lib.dir/src/config/ConfigManager.cpp.o] Fehler 1
In file included from /home/germanikus/GitClones/Hyprland/src/debug/../defines.hpp:3,
from /home/germanikus/GitClones/Hyprland/src/debug/HyprNotificationOverlay.hpp:3,
from /home/germanikus/GitClones/Hyprland/src/debug/HyprNotificationOverlay.cpp:3:
/home/germanikus/GitClones/Hyprland/src/debug/../includes.hpp:10:10: fatal error: libinput.h: No such file or directory
make[4]: *** [CMakeFiles/hyprland_lib.dir/build.make:612: CMakeFiles/hyprland_lib.dir/src/debug/HyprNotificationOverlay.cpp.o] Fehler 1
from /home/germanikus/GitClones/Hyprland/src/debug/HyprDebugOverlay.hpp:3,
from /home/germanikus/GitClones/Hyprland/src/debug/HyprDebugOverlay.cpp:2:
make[4]: *** [CMakeFiles/hyprland_lib.dir/build.make:596: CMakeFiles/hyprland_lib.dir/src/debug/HyprDebugOverlay.cpp.o] Fehler 1
make[3]: *** [CMakeFiles/Makefile2:1083: CMakeFiles/hyprland_lib.dir/all] Fehler 2
make[2]: *** [Makefile:166: all] Fehler 2
make[2]: Verzeichnis „/home/germanikus/GitClones/Hyprland/build“ wird verlassen
make[1]: *** [Makefile:8: release] Fehler 2
make[1]: Verzeichnis „/home/germanikus/GitClones/Hyprland“ wird verlassen
make: *** [Makefile:25: all] Fehler 2
checking those missing headers returns:
find /usr/include/hyprutils -name “WeakPtr.hpp”
/usr/include/hyprutils/memory/WeakPtr.hpp
find /usr/include/ -name “libinput.h”
find /usr/include/ -name “wayland-server.h”
/usr/include/wlroots-0.18/wlr/backend/libinput.h
/usr/include/wlroots-0.19/wlr/backend/libinput.h
/usr/include/libinput.h
/usr/include/wayland-server.h
GCC, G++ and CMake
gcc (GCC) 15.2.1 20260209
g++ (GCC) 15.2.1 20260209
cmake version 4.2.3
Anyone has any ideas on this? For me this seems like a configuration error on my side, but the builds before all worked flawlessly. Or has there been any changes (which broke it at least for me)? Or has anyone a Guide for Arch based distros on installing everything correctly if I’m missing something?
Thanks in advance!
