How to replicate Sway smart borders?
Trying to replicate the behavior of Sway’s smart_borders config option.
smart_borders on|no_gaps|off
If smart_borders are on, borders will only be enabled if the workspace has more than one visible child.
I want borders visible for un-grouped windows and tiled groups.
I do not want a border surrounding a group when it’s the only tile on a display/workspace.
Is this possible? Per the group entry (Variables – Hyprland Wiki) I’m not finding a knob.
Setting the group border color to black is not what I’m looking to achieve here.
This accomplishes the goal:
# Disable borders when only one tile (window or group) exists
workspace = w[tv1], bordersize:0
windowrulev2 = bordersize 0, onworkspace:w[tv1]
# Ensure floating windows still have a border
windowrulev2 = bordersize 2, floating:1
The wiki has a more complete example
Thanks. I like my gaps and rounding as I have them set, but did add fullscreen.
workspace = f[1], bordersize:0
And removed the redundant floating border rule.
