How to focus a specific workspace to a specific monitor on startup
Hyprland 0.56.2 built from branch v0.56.2 at commit efb50993780079460b0cbed1363e2166a2de1d9f clean ([gha] Nix: update inputs).
Date: Wed Aug 5 14:13:21 2026
Tag: v0.56.2, commits: 7661
Hyprgraphics: built against 0.5.1, system has unknown
Hyprutils: built against 0.14.1, system has unknown
Aquamarine: built against 0.15.0, system has unknown
Version ABI string: efb50993780079460b0cbed1363e2166a2de1d9f_aq_0.15_hu_0.14_hg_0.5_hc_0.1_hlg_0.6
I have 2 monitors, i would like to have my secondary monitor (“HDMI-A-1”) focused on workspace 6, while my primary monitor (“DP-2”) is focused on workspace 1 on startup. I specifically do not want to bind a workspace to a specific monitor using hl.workspace_rule, as I like the flexibility of moving workspaces between monitors. Here’s what i have tried:
hl.on("hyprland.start", function ()
	hl.dispatch(hl.dsp.focus({monitor = "HDMI-A-1", workspace = 6}))
	hl.dispatch(hl.dsp.focus({monitor = "DP-2", workspace = 1}))
	hl.dispatch(hl.dsp.focus({monitor = "HDMI-A-1"}))
	hl.dispatch(hl.dsp.focus({workspace = 6}))
	hl.dispatch(hl.dsp.focus({monitor = "DP-2"}))
	hl.dispatch(hl.dsp.focus({workspace = 1}))
Sadly neither of these work. Is there any way to get this to work?
Here is another scenario that ties into this, for when i want to open discord or some other application on my secondary monitor but have my focus on the primary one after startup. With
	hl.exec_cmd("kitty", {workspace = 6, monitor = "HDMI-A-1"})
i am able to open kitty on the correct monitor and workspace, but focus doesn’t move back to my primary monitor, it stays on kitty. Using
doesn’t move my focus either. However
	hl.dispatch(hl.dsp.focus({workspace = 2}))
does move my focus on the secondary monitor away from workspace 6 to 2.
Is there any way to move my focus back to my primary monitor after opening an application on the secondary one?
I did a bunch of research on this but nothing came up. It got to the point where i made this forum post, even though i have never posted one until now. So i hope that someone can help me with this. Thank you.
Can you try with this: Dispatchers – Hyprland Wiki
hl.dispatch(hl.dsp.focus({ workspace = 6, on_current_monitor = true }))
The workspace rule takes a “6 silent” string like this:
hl.exec_cmd("kitty", {workspace = "6 silent", no_initial_focus = true })
This “6 silent” is a remnant of the hyprlang config i think.
on_current_monitor = [true,false] doesn’t seem to be doing anything for me.
{workspace = "6 silent"} and {workspace = 6, no_initial_focus = true} have the same effect for me. Opening kitty in workspace 6 without moving focus to workspace 6. However
hl.exec_cmd("kitty", {workspace = 6, no_initial_focus = true, monitor = "HDMI-A-1"})
moves focus to the secondary monitor, just not on workspace 6 but the currently active workspace for the secondary monitor (ie workspace 2).
Does this topic help?
