High vram usage (700+ MiB )
Hello, I realised when using nvidia-smi to monitor other vram usage that hyprland uses about 750 MiB of vram. From what I understand this seems to be pretty high, are there ways I can troubleshoot this ?
Here’s my system info :
Hyprland 0.50.1 built from branch  at commit 4e242d086e20b32951fdc0ebcbfb4d41b5be8dcc  ([gha] Nix: update inputs).
Date: Sat Jul 19 21:37:06 2025
Tag: v0.50.1, commits: 6291
 aquamarine 0.9.2
 hyprutils 0.8.1
System Information:
System name: Linux
Node name: poseidon
Release: 6.16.4-arch1-1
Version: #1 SMP PREEMPT_DYNAMIC Thu, 28 Aug 2025 19:49:53 +0000
GPU information:
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GA102 [GeForce RTX 3080] [10de:2206] (rev a1) (prog-if 00 [VGA controller])
08:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Cezanne [Radeon Vega Series / Radeon Vega Mobile Series] [1002:1638] (rev c9) (prog-if 00 [VGA controller])
NVRM version: NVIDIA UNIX Open Kernel Module for x86_64  580.82.07  Release Build  (root@)
os-release: NAME="Arch Linux"
PRETTY_NAME="Arch Linux"
ID=arch
BUILD_ID=rolling
ANSI_COLOR="38;2;23;147;209"
HOME_URL="https://archlinux.org/"
DOCUMENTATION_URL="https://wiki.archlinux.org/"
SUPPORT_URL="https://bbs.archlinux.org/"
BUG_REPORT_URL="https://gitlab.archlinux.org/groups/archlinux/-/issues"
PRIVACY_POLICY_URL="https://terms.archlinux.org/docs/privacy-policy/"
LOGO=archlinux-logo
if there are a bunch of windows open, it sounds normal. It’s worth noting gpu drivers often lazy free the vram, so it’s “taken”, but if anything else needs it, it will drop.
I see, I only had like 3 windows open (No Man’s Sky, Firefox, and Vesktop). Is it still normal ? It also kinda hindered my performance with No Man’s Sky (despite having a 3080 it’s still down to 700 MiB :sweat_smile: )
sounds normal tbh. Worth noting a bunch of this is shared vram.
As in, normal RAM ? Because since I’m on Nvidia every bit of vram used is fully coming from the gpu sadly
That’s the case for all dedicated GPUs, they only use system RAM if they are integrated GPUs. Vaxry means VRAM that is shared between processes.
