Hey guys, I am having a bit of a problem setting up and configuring hyprpaper and was just looking for a little help, I’m probably just missing something small or done something wrong so apologies in advance if I’ve done something idiotic.
I am running Arch Linux as a VM in Virtual Box, and I am using SDDM as my DM.
Hyprland 0.53.0
When I run hyprpaper with the following config:
wallpaper{
monitor = 0
path = /home/lucas/.config/backgrounds/hyprlock.png
fit_mode = cover
splash = false
ipc = on
I receive the following response without my background changing and nothing further happening
DEBUG ]: Welcome to hyprpaper!
built from commit ()
DEBUG ]: Found 1 output(s)
DEBUG ]: Monitor Virtual-1 has no target: no wp will be created
If I change monitors to be empty like so:
wallpaper{
monitor =
fit_mode = cover
splash = false
ipc = on
I receive the following response adding WARNs and ASSERTION FAILED!:
WARN from aquamarine ]: GBM: Using modifier-less allocation
ASSERTION FAILED!
[core] Disconnected from pollfd id 0
at: line 349 in Backend.cpp[HT] Assertion failed!Aborted (core dumped) hyprpaper
If I then change monitors to be Virtual-1(My only monitor) like so:
wallpaper{
monitor = Virtual-1
fit_mode = cover
splash = false
ipc = on
I receive the following response which now adds the error “w1_display#1: error 1: invalid arguments for w1_surface#16.attach”.
I also tried to run hyprpaper via IPC:
hyprctl hyprpaper wallpaper " , /home/lucas/.config/backgrounds/hyprlock.png
but was met with the following:
[hw] err: err: 111
error: can't send: failed to connect to hyprpaper (is it running?)
My hyprctl monitors -all output shows only “Virtual-1”
I have hyprpaper set to start on startup in my hyprland.conf aswell but my wallpaper does not change
Let me know if I can provide any further details.
I appreciate anybody who takes the time to read this and especially anybody who offers any help.
Thanks
