hello first off i just installed hyprland today
i am switching off from kde due to a large amount of bugginess on my gentoo system and speficaly switched to hyprland for the hdr support.
i right now have hyprland configered to run my main monitor (samsung odesy neo g7 (4k 165 hz (with dsc, 120 hz with out it) 1000 nits). but for hdr content it looks weird like when i try mosnter hutner wilds which correctly displays hdr content in kde plasma it looks like it’s still sdr even tho hyprland switched to displaying hdr and the game thinks it’s outputting hdr. also i can’t tell a diffrence between any of the brightness vaules in monster hunter wilds between 10 and 100, the onyl brightness that have any visable diffrence are 1 threw 10. this is very much not normal
hyprland conf (litalry installed today so nto complete)
monitor=HDMI-A-2,3840x2160@60, 0x0, 1.25 >
#monitor=DP-1, 3840x2160@165, auto-center-right, 1, bitdepth,10,cm,hdr,sdrbrightness,1.5,sdrsaturation>
monitor=DP-5, 1920x1080@60, auto-center-right, 1, transform,1 # lg 1
monitor=DP-6, 1920x1080@60, auto-center-right, 1, transform,3 # lg 2
exec-once = waybar
exec-once = hyprpaper
exec-once = hypridle
exec-once = swaync
exec-once = nm-tray
exec-once = hyprpolkitagent
exec-once = wl-paste --type text --watch clipman store
exec-once = gsettings set org.gnome.desktop.interface color-scheme ‘prefer-dark’
env = GTK_THEME,Breeze-Dark
exec-once = gsettings set org.gnome.desktop.interface gtk-theme ‘Breeze-Dark’
env = QT_STYLE_OVERRIDE,breeze
bind = SUPER, R, exec, walker
bind = SUPER SHIFT, S, exec, hyprshot -m region
bind = , F12, exec, hyprshot -m screen
bind = SUPER, Q, exec, kitty
bind = SUPER, Y, exec, /opt/youtube-music/youtube-music
bind = SUPER, F, exec, flatpak run one.ablaze.floorp
bind = SUPER, S, exec, signal-desktop --password-store=“kwallet6”
bind = SUPER, V, exec, vesktop-bin
bind = SUPER, K, killactive
bind = SUPER, W, exec, steam -steamos3
binde = , XF86AudioRaiseVolume, exec, wpctl set-volume -l 1.5 @DEFAULT_AUDIO_SINK@ 5%+
binde = , XF86AudioLowerVolume, exec, wpctl set-volume @DEFAULT_AUDIO_SINK@ 5%-
bind = , XF86AudioPlay, exec, playerctl play-pause
bind = , XF86AudioNext, exec, playerctl next
bind = , XF86AudioPrev, exec, playerctl previous
bind = , XF86AudioStop, exec, playerctl stop
misc{
vrr = 1
experimental {
xx_color_management_v4 = true
render {
cm_auto_hdr = 1
cm_fs_passthrough = 1
game launch options PROTON_USE_NTSYNC=1 PROTON_ENABLE_WAYLAND=1 VKD3D_CONFIG=hdr PROTON_ENABLE_HDR=1 ENABLE_HDR_WSI=1 gamemoderun %command%
system info
c2@gentoobtw ~ $ fastfetch
-/oyddmdhs+:. c2@gentoobtw
-odNMMMMMMMMNNmhy± ------------ -yNMMMMMMMMMMMNNNmmdhy+- OS: Gentoo Linux x86_64omMMMMMMMMMMMMNmdmmmmddhhy/ Kernel: Linux 6.17.8-cachyos omMMMMMMMMMMMNhhyyyohmdddhhhdo Uptime: 2 hours, 23 mins
.ydMMMMMMMMMMdhs++so/smdddhhhhdm+ Packages: 2275 (emerge), 33 (flatpak-system), 1 (flatpak-user) oyhdmNMMMMMMMNdyooydmddddhhhhyhNd. Shell: bash 5.3.3 :oyhhdNNMMMMMMMNNNmmdddhhhhhyymMh Display (LG FULL HD): 1080x1920 in 22", 60 Hz [External] .:+sydNMMMMMNNNmmmdddhhhhhhmMmy Display (LG FULL HD): 1080x1920 in 22", 60 Hz [External] /mMMMMMMNNNmmmdddhhhhhmMNhs: Display (Odyssey G7): 3840x2160 in 32", 165 Hz [External] oNMMMMMMMNNNmmmddddhhdmMNhs+ WM: Hyprland 0.51.1 (Wayland)sNMMMMMMMMNNNmmmdddddmNMmhs/. Theme: Breeze-Dark [GTK2], Breeze [GTK3/4]
/NMMMMMMMMNNNNmmmdddmNMNdso: Icons: Vivid-Dark-Icons [GTK2/3/4] +MMMMMMMNNNNNmmmmdmNMNdso/- Font: Noto Sans (10pt) [GTK2/3/4] yMMNNNNNNNmmmmmNNMmhs+/- Cursor: breeze (24px)
/hMMNNNNNNNNMNdhs++/- Terminal: kitty 0.44.0/ohdmmddhys+++/:. Terminal Font: LiberationMono (11pt)-//////:–. CPU: AMD Ryzen 9 9950X3D (32) @ 5.76 GHz
GPU 1: AMD Radeon RX 7900 XTX [Discrete]
GPU 2: AMD Radeon Graphics [Integrated]
GPU 3: AMD Radeon RX 6600 [Discrete]
gpu driver: AMD Radeon Graphics (radeonsi, raphael_mendocino, LLVM 20.1.8, )
Memory: 8.77 GiB / 91.97 GiB (10%)
Swap: 0 B / 16.00 GiB (0%)
Disk (/): 741.64 GiB / 914.07 GiB (81%) - xfs
Disk (/run/media/hdd): 5.03 TiB / 10.83 TiB (46%) - ext4
Disk (/run/media/pciessd): 62.18 GiB / 476.71 GiB (13%) - xfs
Disk (/run/media/wdssd): 1.02 TiB / 1.82 TiB (56%) - xfs
Locale: C.utf8
c2@gentoobtw ~ $ emerge -pv gui-wm/hyprland
- IMPORTANT: config file ‘/etc/portage/package.accept_keywords/keywords’ needs updating.
- See the CONFIGURATION FILES and CONFIGURATION FILES UPDATE TOOLS
- sections of the emerge man page to learn how to update config files.
These are the packages that would be merged, in order:
Calculating dependencies… done!
Dependency resolution took 1.35 s (backtrack: 0/20).
[ebuild R ~] gui-wm/hyprland-0.51.1::gentoo USE=“X qtutils systemd” 53010 KiB
Total: 1 package (1 reinstall), Size of downloads: 53010 KiB
c2@gentoobtw ~ $
