Forceworkspace dispatcher would be great
workspace dispatcher does back and forth when set up this way, but it would really benefit the system, especially with automatic laptop handling scripts, if we could force a workspace instead of flipping out of it when its already on screen. :slight_smile:
Intended behaviour:
forceworkspace 1 simply ensures workspace 1 is visible, even if it still is.
You have this enabled
Yes. Thats why I request this feature. :slight_smile:
I would like to have a simple way to “switch to workspace 1” on startup with a tool I currently invent to allow for “scenario roaming” with Hyprland.
The tool I’m currently implementing is about “enabling quasi-clamshell” mode on laptops (you can leave the laptop open and still have its screen and keyboard backlight off) but will be about true “scenario roaming” with auto-detect / multiple modes and all that later.
why not just disable this option?
Yes, I did that for a while, but found out that I like it actually.
My use case for this option is, for example, to have (at work) my browser with TeamCity on workspace 10 and then a lot of Rider and vscode instances on the other workspaces.
But yes, if this would be disruptive to implement or ultra low priority - I can totally live with as it is for now, of course.
hyprctl --batch 'keyword binds:workspace_back_and_forth 0; dispatch workspace 1; keyword binds:workspace_back_and_forth 1' should work
Yes, it does. Stupid of me not to think about, thank you very much, thats of course a great solution even! :slight_smile:
