First thing to do on Hyprland
After setting up basic stuff on Hyprland when first installing it, what do most of you guys do first to make Hyprland good for you or would be overall good for anyone. Animations? Custom scripts? Share your ideas please. My current setup is kinda basic, I want to maybe spice it up.
I currently use a tweaked version of ML4W… really good dotfiles.. and im quite active in the discord and trying to help new users of ml4w dotfiles
Take a look at Useful Utilities – Hyprland Wiki and install what you like.
Ah yeah, I’ve seen that. I was more talking about maybe unique stuff that people maybe do
Key things?
  • change / set up binds
  • install key software (launcher, some utilities like xdph, etc, see Useful utilities)
  • poke around at the variables, see the Variables page.
then have fun :P
Plugins are cool, I use three.
Ah, I forgot about the variables page. Yeah I’ll def look into that
after installing hypr i just setup my dotfiles and and play cs2 :squinting_face_with_tongue:
Using HyDE, you rDevelopment Environment. :joy:
  • that would be 20 lines.
Spend countless hours writing your own taskbar and widgets but realize you prefer a very simple layout and now your desktop looks like you did absolutely nothing :slight_smile:
im tryna learn quickshell cuz ive seen some very neat stuff when people use it so id recommend that
same here, haven’t been able to figure it out quite yet outside the basics, you got any dotfiles yet?
Which plugins do you use? I’m ~6 months into Hyprland and haven’t found a need to look into them yet.
I used hyprgrass and an auto rotation one back on my tablet, currently I use none again
First thing I do is change my keybinds to be more like what I’m used to (eg: i3 Mod+Return for terminal, Mod+D for applications, Mod+Q to kill window). 2nd thing I do is change the background.
install end4’s dots and change some defaults like keybinds, setup autologin on gdm and set the lockscreen to start on boot, set monitor stuff obv, add the firefox template to matugen and install pywallfox. uhhhhhhhhh then i just install all my programs and setup flatpak and thats is!
oh and i use 1 whole plugin split-monitor-workspaces, i can’t use dual monitors without it lmao
