Hyprland 0.55.3 built from branch v0.55.3 at commit fe5fe79a29ac3adaf3e75560b2f4b7a6d58b31c9 clean ([gha] Nix: update inputs).
Date: Sun Jun 7 10:35:01 2026
Tag: v0.55.3, commits: 7366
Aquamarine: built against 0.12.0, system has 0.12.0
Version ABI string: fe5fe79a29ac3adaf3e75560b2f4b7a6d58b31c9_aq_0.12_hu_0.13_hg_0.5_hc_0.1_hlg_0.6
I don’t understand how workspaces work with external monitors. I have an awkward setup and I would like to know how it’s done properly for my use case.
(Config is below)
Acknowledgement
This is a user-error. I just don’t know how and I’m looking for answers.
Use case
I have a desktop and a laptop that both use the same config. My desktop correctly assumes the config for DP-1 while my laptop uses eDP-1. DP-3 on the other hand is for external monitors I plug in whenever I am presenting something to an audience on a large screen.
The problem
In DP-3 config, I uncomment mirror and change the laptops (eDP-1) built in display’s resolution and scale manually. I do this because I find the behavior for external monitors confusing.
I don’t know on which workspace the external monitor decides to be on and so I blindly switch between workspaces and open a window to see where it happens. When I do find the correct workspace and move the window I want to share to said workspace, then it works but another problem comes up:
When I use SUPER+SHIFT+[1-10] to move a window to a different workspace, then it behaves differently when doing so from the workspace with an external monitor. If the only window on the external workspace is moved that way, the workspace that is moved to becomes the external workspace.
As a result I would have to awkwardly spawn a window in the external workspace first before moving it out, bringing the new window in and closing the temporary window.
Ideal scenario
The external monitor is binded to a predictable workspace (like workspace 1) and does not budge like in the aforementioned case of moving windows. Bonus points if I do not need to change config in real time to make things happen and only need to plug the monitor cable in.
hyprland.lua:
--- MONITORS ----
hl.monitor({
output = "DP-1",
mode = "2560x1440@144",
position = "0x0",
scale = "1",
hl.monitor({
output = "eDP-1",
mode = "2256x1504@60",
-- mode = "3840x2160@60",
position = "0x0",
scale = "1.33",
-- scale = "2",
hl.monitor({
output = "DP-3",
position = "2256x0",
scale = "1.33",
-- mirror = "eDP-1"
