Error with libhyprgraphics on hyprutils-git
I had the same problem as this thread on the garuda forum: Hyprland won't start because of libhyprgraphics - Hyprland - Garuda Linux Forum
Downgrading from hyprutils-git to hyprutils fixes, but of we should be using the -git with hyprland-de.
Do you have other solution, or is it a buf that will be fixed? @vaxry
You shoud absolutely not be using -git with DE.
For the errors, it is your fault and responsibility: FAQ – Hyprland Wiki
Oh, I don’t know why I had the -git installed then, I’ll trace why and fix it. Thanks!
