I have Envision XR up and running just fine on my system, but in the logs I keep getting this error:
Info [/home/autune/.local/share/envision/monado/src/xrt/compositor/main/comp_window_direct_wayland.c:comp_window_direct_wayland_init]
Found no connectors available for direct mode
It all works, the headset tracks and the games launch, it just pops up the VR’s view in a window on Hyprland instead of in the headset’s display.
This is what hyprctl monitors all shows:
❯ hyprctl monitors all
Monitor DP-1 (ID 0):
[email protected] at 0x0
description: Samsung Electric Company LC49G95T H4ZR901149
make: Samsung Electric Company
model: LC49G95T
physical size (mm): 1190x340
serial: H4ZR901149
active workspace: 1 (1)
special workspace: 0 ()
reserved: 0 57 0 0
scale: 1.00
transform: 0
focused: yes
dpmsStatus: 1
vrr: false
solitary: 0
activelyTearing: false
tearingBlockedBy: next frame is not torn,user settings,missing candidate
directScanoutTo: 0
directScanoutBlockedBy: user settings,missing candidate
disabled: false
currentFormat: XRGB8888
mirrorOf: none
availableModes: [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected]
colorManagementPreset: srgb
sdrBrightness: 1.00
sdrSaturation: 1.00
sdrMinLuminance: 0.20
sdrMaxLuminance: 80
And this is what my monitors.conf looks like:
# Generated by nwg-displays on 2026-01-12 at 14:27:27. Do not edit manually.
monitor=DP-1,[email protected],0x0,1.0
monitor=DP-2,[email protected],0x0,1.0
monitor=DP-2,disable
