Hi
I installed linux mint, with Cinnamon, a while ago and I had this issue where I couldn’t have both my monitors plugged into my 980ti at the same time. One monitor (main) was plugged into the hdmi port, and the other monitor (secondary) was plugged into the DVI port (its an old monitor). The problem is that each one works perfectly fine, but the second I try to put both in, it defaults to the hdmi, as if the dvi is ignored. My monitor for the DVI just keeps saying “no signal”, but when I turn off the hdmi monitor, all of a sudden the dvi monitor works. And every so often I see flashes of the wallpaper on my DVI monitor. I tried fixing it but I got frustrated and moved on just using one monitor.
Recently I installed ARCH LINUX minimal, and installed hyperland. But an important point is, I got a 750ti in my pc now as well, and I put the DVI monitor on the 750ti.
For a brief moment my monitors were both working with hyperland. GREAT!
EXCEPT the next morning I turn on my computer and I got the exact same problem. I’ve tried asking all the damn LLM models, and it just goes in circles, nothing gets resolved. Tried googling, still not much luck. I know nvidia is shit for linux in general, but its what I got.
Here is some context:
- hyprland monitors shows that both monitors are being picked up by my system (Acer AIO LCD + Toshiba LCD-Monitor)
- nvidia-smi shows both gpus are detected and running
- Nvidia driver version is 580.82.09
- I’ve tried various hyprland configs, and so far it doesn’t seem like its doing anything. the underlying problem seems to not care about hyprland’s config.
So this is my problem, and I’m wondering if there’s anyone who knows what’s going on here, or at least can point me in the right direction, because if chat gpt or claude tells me one more time to check if the cables have a bad connection I’m gonna throw my computer into the pool.
