I want to set 4 finger pinchout to hyprexpo, the documentation linked above mentions keyword and says same as gesture. I tried the following but error pops up →
hyprexpo-gesture = 4, pinch , hyprexpo:expo
You didn’t follow the README. It says “supported gestures: expo” not hyprexpo:expo. It’s just expo.
Sorry i am still getting confused, i tried following permutations but getting error in some and no-effect on others.
plugin {
hyprexpo {
hyprexpo-gesture = 3, vertical , expo
Produces no effect
Says that: config option does not exist.
Says that: Invalid gesture: expo
this is correct, make sure the plugin is loaded.
