Copying images in Discord (Xwayland) is not working
Hyprland 0.53.1 built from branch v0.53.1 at commit ab1d80f3d6aebd57a0971b53a1993b1c1dfe0b09 clean (version: bump to 0.53.1).
Date: Fri Jan 2 21:20:57 2026
Tag: v0.53.1, commits: 6766
Hyprlang: built against 0.6.7, system has 0.6.8
Version ABI string: ab1d80f3d6aebd57a0971b53a1993b1c1dfe0b09_aq_0.10_hu_0.11_hg_0.5_hc_0.1_hlg_0.6
Copying an image from an application running under Xwayland (like Discord) and pasting it into an application running natively on Wayland (like Telegram, Firefox) does not work.
This issue specifically affects the Xwayland -> Wayland. Other combinations, such as Wayland -> Wayland, Xwayland -> Xwayland and Wayland -> Xwayland do work. The bug is likely not limited to Discord and affects other applications running under Xwayland as well
Reproduction Steps
  1. Launch Discord and make sure it is using Xwayland
  2. Copy an image (as an example from #memes)
  3. Attempt to paste the image into an application running natively on Wayland (for example Telegram or Firefox)
  4. Result: Nothing happens (the image is not pasted)
