Hi.
If I do a single color like hyprctl dispatch setprop active activebordercolor “rgb(180,142,173)” it works, but when when I add another color:
hyprctl dispatch setprop active activebordercolor “rgb(180,142,173) rgb(142,180,149)” it no longer works.
Same thing when I do with hex ARGB.
I checked the docs, seems like the syntax is correct, whats the problem here?
