Can hyprland combine multiple physical monitors into a single virtual monitor?
Hyprland 0.56.2 built from branch v0.56.2 at commit efb50993780079460b0cbed1363e2166a2de1d9f clean ([gha] Nix: update inputs).
Date: Wed Aug 5 14:13:21 2026
Tag: v0.56.2, commits: 7661
Hyprutils: built against 0.14.0, system has 0.14.1
Aquamarine: built against 0.14.0, system has 0.14.0
Version ABI string: efb50993780079460b0cbed1363e2166a2de1d9f_aq_0.14_hu_0.14_hg_0.5_hc_0.1_hlg_0.6
Hello, on my current display server I use the xrandr --setmonitor command to combine multiple physical monitors into a single virtual monitor. Is there any way to use Lua to configure Hyprland to be able to do the same thing?
these are the directly analogous equivalent issues in other repositories:
I had a long list of other URLs to post here but the system said new users are only allowed to post 2 links
Afaik, no Wayland compositor has achieved this.
Closest effort:
Conversely, a popular feature request for Hyprland:
thanks for the updated information about this as it relates to hyprland. I am a “single issue user”; this limitation of wayland is what keeps me on Xorg. Once a wayland compositor successfully implements this feature with correct, pixel-perfect accuracy to the behavior of Xorg with the Marco or Openbox window managers, it will probably be the first wayland compositor I try switching to from Xorg.
