I have recognized that binds seem to act weird when I tried to move my config to the new Lua format. The following example works fine using the .conf file, but not the .lua configuration:
Effectively, pressing the Mod key does not work - consequently none of the binds work. wev or xkbcli interactive-wayland both recognize the keysym Super_L properly.
Using the following on latest Arch:
hyprland -v
Hyprland 0.55.1 built from branch v0.55.1 at commit a47147bc095e5b3be3eb8bd04f0ac242b968cd4d clean ([gha] Nix: update inputs).
Date: Wed May 13 22:55:46 2026
Tag: v0.55.1, commits: 7311
I am not sure if this is the intended behavior. Because it would be awesome if you could distinguish between a Shift_L and Shift_R but still be able accept both using SHIFT.
We have modifiers and keys. A keybind has a modifier (optional) and a key.
I am not sure if you can have 2 keys. Edit: you can have multiple keys.
Modifiers: From LuaBindingsTopLevel.cpp
static std::optional modFromSv(std::string_view sv) {
if (sv == “SHIFT”)
return HL_MODIFIER_SHIFT;
if (sv == “CAPS”)
return HL_MODIFIER_CAPS;
if (sv == “CTRL” || sv == “CONTROL”)
return HL_MODIFIER_CTRL;
if (sv == “ALT” || sv == “MOD1”)
return HL_MODIFIER_ALT;
if (sv == “MOD2”)
return HL_MODIFIER_MOD2;
if (sv == “MOD3”)
return HL_MODIFIER_MOD3;
if (sv == “SUPER” || sv == “WIN” || sv == “LOGO” || sv == “MOD4” || sv == “META”)
return HL_MODIFIER_META;
if (sv == “MOD5”)
return HL_MODIFIER_MOD5;
return std::nullopt;
Keys: These go to xkbcommon-keysyms.h and are case insensitive i believe:
// Normal keys A, B, C
#define XKB_KEY_Shift_L 0xffe1 /* Left shift /
#define XKB_KEY_Shift_R 0xffe2 / Right shift /
#define XKB_KEY_Control_L 0xffe3 / Left control /
#define XKB_KEY_Control_R 0xffe4 / Right control /
#define XKB_KEY_Caps_Lock 0xffe5 / Caps lock /
#define XKB_KEY_Shift_Lock 0xffe6 / Shift lock */
#define XKB_KEY_Meta_L 0xffe7 /* Left meta /
#define XKB_KEY_Meta_R 0xffe8 / Right meta /
#define XKB_KEY_Alt_L 0xffe9 / Left alt /
#define XKB_KEY_Alt_R 0xffea / Right alt /
#define XKB_KEY_Super_L 0xffeb / Left super /
#define XKB_KEY_Super_R 0xffec / Right super /
#define XKB_KEY_Hyper_L 0xffed / Left hyper /
#define XKB_KEY_Hyper_R 0xffee / Right hyper */
Modifiers is something different from a key, and as such handled differently.
Super_L is a key, SUPER is a modifier. Super_L and Super_R both set the SUPER flag when pressed.
And yes, it’s possible to make hyprland handle L and R, but requires some work in the keybindmanager in the source. No one have just gotten around to it yet i guess. Open a feature request and maybe someone will pick it up.
I think so as well. I have been struggling to get hl.bind("Control_L + Alt_L + L", ...)
to work, finally after reading a bunch of threads and then this thread I realized I can to use CTRL + ALT + L, as currently _L _R are not supported, and that those keys trigger modifiers that I can use instead.
I would appreciate if someone could give me something to read about those modifiers Is this something hyprland specific? I didn’t know that was a thing, I thought they were behaving like normal letter keys.
