Are keysyms combos working ? (binds = ...&...)
Guys, I’ve been trying all combos possible for this to work :
binds = Super_L, Q&H, exit,
To no avail.
Here are the variants I tried :
binds = SUPER, q&h, exit,
binds = Super_L, q&h, exit,
binds = SUPER, Q&H, exit,
Is anyone using this feature successfully ? What am I missing ?
Sure I can come up with another binding that can’t be pressed accidentally, sure, but I don’t understand why it fails and this is very annoying.
Nope. Works for the thing you want to do. What doesn’t work is having it without a modifier, and you can’t use it if a key changes certain states. Like changing monitor focus, workspace focus or opens a special workspace.
If for example you have a bind like:
bind = super, h, focusmonitor, 2
your binds binding will never work.
Oh, I indeed have super+h binded… now that you mention it, seems logical enough. Thanks :slight_smile:
edit : *** trials have been condusted ***
Even then, I can’t seem to make it work…
I even tried a binding with key and modifiers that hasn’t been used anywhere, and yet it’s not working.
I’ll just give up on that functionality. Maybe it is taking advantage of libQtCore.so.6.9 which I am missing, plus I’m using the version 0.51.1, which is not the latest…
Anyhow, thanks pal :slight_smile:
