Running in dwindle mode, I usually have about 6-8 windows open. The textual/terminal ones are usually still usable even when they get sized down to 1/8 of the screen size, however GUIs do not always look that great at that point.
Is there a way that I can set a keybind or even a class that when focused floats and resizes the window while in use and then un-floats and returns the window properties to its former state when focus is lost, or another keybind is pressed? This is primarily for the GUIs. Hopefully Iām explaining this well enough, if not, I can draw something up.
