Adjusting resolution on TV
Adjusting Hyprland resolution on TV:
is there a way to adjust resolution on a TV? i had tried to activate 10 bit support and change resolution and scale in nwg displays, but the screen just got smaller and the top dock didn’t move a bit.
TVs are notoriously wonky, it might be the TVs fault
Often times TVs will have a setting you can change which might help.
My old tv had a setting under Picture→Advanced called “Aspect Ratio” which I could tweak to make it behave nicer with my PC. Choices were “Full (100%)” and “Point-to-Point”. Full was what I wanted.
