Absolute window sizing
I have been trying to do a bind to a command that resizes a window to an absolute size using the following command:
hl.bind(mainMod .. "+ R", hl.dsp.window.resize({ x=600, y=400, relative="false" }))
but it always acts relative, increasing the size of the window in increments of x and y. Any idea what I am doing wrong here?
Thanks, Flint
@FlintRock, try changing the relative property in ur options table to a boolean, rather than a string.
I think lua will coerce the string value to a truthy boolean.
TLDR, try:
hl.bind(mainMod .. "+ R", hl.dsp.window.resize({ x=600, y=400, relative=false }))
@vito Thanks for the suggestion… It did something..
hl.bind(mainMod .. “+ R”, hl.dsp.window.resize({ x=5, y=5, relative=false })) you would think would make a tiny window but it basically maximizes the window tile to available space wheras
hl.bind(mainMod .. “+ R”, hl.dsp.window.resize({ x=5, y=5, relative=“false” })) makes the windows smaller by it looks like 5 pixels.
I hesitate to submit it as a bug because history shows I’m always wrong, but thanks for the input it was much appreciated.
Interestingly if I float a window it responds as expected.
Very strange… my suggestion was just off the top of my head. I’ll have a play around with some binds soon, and see if i get the same behaviour, then report back.
