Here is the code:
---- KEYBINDINGS ----
local mainMod = "SUPER" -- Sets "Windows" key as main modifier
-- Example binds, see https://wiki.hypr.land/Configuring/Basics/Binds/ for more
hl.bind(mainMod .. " + RETURN", hl.dsp.exec_cmd(terminal))
local closeWindowBind = hl.bind(mainMod .. " + Q", hl.dsp.window.close())
-- closeWindowBind:set_enabled(false)
hl.bind(mainMod .. " + E", hl.dsp.exec_cmd("command -v hyprshutdown >/dev/null 2>&1 && hyprshutdown || hyprctl dispatch 'hl.dsp.exit()'"))
hl.bind(mainMod .. " + T", hl.dsp.exec_cmd(fileManager))
-- hl.bind(mainMod .. " + V", hl.dsp.window.float({ action = "toggle" }))
hl.bind(mainMod .. " + R", hl.dsp.exec_cmd(menu))
-- hl.bind(mainMod .. " + P", hl.dsp.window.pseudo())
-- hl.bind(mainMod .. " + J", hl.dsp.layout("togglesplit")) -- dwindle only
hl.bind(mainMod .. " + M", hl.dsp.window.fullscreen({ mode = "maximized" , action = "toggle" }))
hl.bind(mainMod .. " + F", hl.dsp.window.fullscreen({ mode = "fullscreen" , action = "toggle" }))
-- Move focus with mainMod + arrow keys
hl.bind(mainMod .. " + left", hl.dsp.focus({ direction = "left" }))
hl.bind(mainMod .. " + right", hl.dsp.focus({ direction = "right" }))
hl.bind(mainMod .. " + up", hl.dsp.focus({ direction = "up" }))
hl.bind(mainMod .. " + down", hl.dsp.focus({ direction = "down" }))
-- Switch workspaces with mainMod + [0-9]
-- Move active window to a workspace with mainMod + SHIFT + [0-9]
for i = 1, 10 do
local key = i % 10 -- 10 maps to key 0
hl.bind(mainMod .. " + " .. key, hl.dsp.focus({ workspace = i}))
hl.bind(mainMod .. " + SHIFT + " .. key, hl.dsp.window.move({ workspace = i }))
-- Example special workspace (scratchpad)
hl.bind(mainMod .. " + S", hl.dsp.workspace.toggle_special("magic"))
hl.bind(mainMod .. " + SHIFT + S", hl.dsp.window.move({ workspace = "special:magic" }))
-- Scroll through existing workspaces with mainMod + scroll
hl.bind(mainMod .. " + mouse_down", hl.dsp.focus({ workspace = "e+1" }))
hl.bind(mainMod .. " + mouse_up", hl.dsp.focus({ workspace = "e-1" }))
-- Move/resize windows with mainMod + LMB/RMB and dragging
hl.bind(mainMod .. " + mouse:272", hl.dsp.window.drag(), { mouse = true })
hl.bind(mainMod .. " + mouse:273", hl.dsp.window.resize(), { mouse = true })
-- Laptop multimedia keys for volume and LCD brightness
hl.bind("XF86AudioRaiseVolume", hl.dsp.exec_cmd("wpctl set-volume -l 1 @DEFAULT_AUDIO_SINK@ 5%+"), { locked = true, repeating = true })
hl.bind("XF86AudioLowerVolume", hl.dsp.exec_cmd("wpctl set-volume @DEFAULT_AUDIO_SINK@ 5%-"), { locked = true, repeating = true })
hl.bind("XF86AudioMute", hl.dsp.exec_cmd("wpctl set-mute @DEFAULT_AUDIO_SINK@ toggle"), { locked = true, repeating = true })
hl.bind("XF86AudioMicMute", hl.dsp.exec_cmd("wpctl set-mute @DEFAULT_AUDIO_SOURCE@ toggle"), { locked = true, repeating = true })
hl.bind("XF86MonBrightnessUp", hl.dsp.exec_cmd("brightnessctl -e4 -n2 set 5%+"), { locked = true, repeating = true })
hl.bind("XF86MonBrightnessDown",hl.dsp.exec_cmd("brightnessctl -e4 -n2 set 5%-"), { locked = true, repeating = true })
-- Requires playerctl
hl.bind("XF86AudioNext", hl.dsp.exec_cmd("playerctl next"), { locked = true })
hl.bind("XF86AudioPause", hl.dsp.exec_cmd("playerctl play-pause"), { locked = true })
hl.bind("XF86AudioPlay", hl.dsp.exec_cmd("playerctl play-pause"), { locked = true })
hl.bind("XF86AudioPrev", hl.dsp.exec_cmd("playerctl previous"), { locked = true })
---- MY PROGRAMS ----
-- Set programs that you use
local terminal = "uwsm app -- alacritty"
local fileManager = "uwsm app -- thunar"
local menu = "uwsm app -- $(tofi-drun)"
