In case people going over to 0.53.0 missed it, there’s a new syntax for window and layer rules.
So i made a converter.
And now no one can complain that i didn’t advertise it.
Thanks! I wanted to put it in the news post but couldn’t find it. :P
Fwiw we could pin this for the time being
sure, can do that :)
Thank you, it was really helpful.
Yeah, noticed that to late. I created a vim macro instead
Thank it saved my night
Thanks. It’d be great if hyprland offered autoconversion natively tho!
I disagree. Our policy is that Hyprland should never touch your config other than to read it. It’s your config.
Thank you so much! It worked perfectly.
I used this (i think correctly) and it fixed the windowrules but idk how I’m meant to fox my opacity bind because it doesn’t work. I’m using the JaKooLit dotfiles and my current bind is:
bind = $mainmod CTRL, O, exec, hyprctl setprop active alphaoverride toggle
This was generated by Gemini because the wiki confused me but idk how to fix it. Please help.
hyprctl dispatch setprop active opaque toggle
you could have it read the window/layer rules from the config, modify them in a buffer and output it to stdout only, and only the rules part. let the user decide what to do with it
Thanks for saving my time!
I have a question guys is there any documentation about the config grammar ? I found this
GitHub - tree-sitter-grammars/tree-sitter-hyprlang: hyprlang grammar for tree-sitter · GitHub but I’m not sure if it’s updated
