Hi everyone,
I recently switched from Windows 10 to CachyOS and I’m building my own Hyprlandconfiguration. I’m hitting a wall when logging out and I hope someone can point me in the right direction.
Whenever I log out using hyprctl dispatch exit (via wlogout), instead of returning to the SDDM login screen, I get a black screen with a blinking underscore in the top-left corner. To get back in, I have to switch to TTY3 (Ctrl+Alt+F3), log in, and manually run Hyprland.
My Setup:
OS: CachyOS
GPU: NVIDIA RTX 2080 (using proprietary drivers)
CPU: Intel i7-8700
Display Manager: SDDM (using Candy theme)
Logs (journalctl -b -u sddm): I’ve noticed that sddm-helper seems to crash exactly when I try to exit the session:
dic 28 09:35:33 antonimodev sddm[913]: Session started true
dic 28 09:35:46 antonimodev sddm[913]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
dic 28 09:35:46 antonimodev sddm[913]: Auth: sddm-helper (...) crashed (exit code 1)
dic 28 09:35:46 antonimodev sddm[913]: Auth: sddm-helper exited with 1
Has anyone experienced this specific sddm-helper crash upon exiting Hyprland on NVIDIA? Is there a specific SDDM configuration or a wrapper script I should be using for a clean exit?
Thanks in advance!
