New monitor make Hyprland crash on input switch
Hyprland 0.55.4 built from branch v0.55.4 at commit a0136d8c04687bb36eb8a28eb9d1ff92aea99704 clean ([gha] Nix: update inputs).
Date: Thu Jun 11 17:10:04 2026
Tag: v0.55.4, commits: 7378
Aquamarine: built against 0.12.0, system has 0.12.1
Version ABI string: a0136d8c04687bb36eb8a28eb9d1ff92aea99704_aq_0.12_hu_0.13_hg_0.5_hc_0.1_hlg_0.6
Setup:
I have bought new monitor AOC Q27G3XMN/BK.
My current setup is 3 monitors, the new one in the middle. Old ones are 1080p, the new one is 1440p.
I have 2 computers and this new monitor is connected to both. So I switch input frequently.
Problem:
When I switch from other machine to my Arch Linux my Hyprland is restarting. Because of the restart my spotify and signal app crash as well.
Logs:
xdg-desktop-portal-hyprland
Jul 28 13:30:37 archlinux xdg-desktop-portal-hyprland[989321]: [LOG]  | Got interfwl_display#1: error 0: invalid object 13
Jul 28 13:30:37 archlinux systemd[1020]: xdg-desktop-portal-hyprland.service: Main process exited, code=dumped, status=11/SEGV
Jul 28 13:30:37 archlinux systemd[1020]: xdg-desktop-portal-hyprland.service: Failed with result 'core-dump'.
Jul 28 13:30:37 archlinux systemd[1020]: xdg-desktop-portal-hyprland.service: Scheduled restart job, restart counter is at 2.
Jul 28 13:30:37 archlinux systemd[1020]: Starting Portal service (Hyprland implementation)...
Jul 28 13:30:37 archlinux systemd[1020]: Started Portal service (Hyprland implementation).
Jul 28 13:30:37 archlinux xdg-desktop-portal-hyprland[1016522]: [LOG] Initializing xdph...
Jul 28 13:30:37 archlinux xdg-desktop-portal-hyprland[1016522]: [LOG] XDG_CURRENT_DESKTOP set to Hyprland
Jul 28 13:30:37 archlinux xdg-desktop-portal-hyprland[1016522]: [LOG] Gathering exported interfaces
Signal
(before switch)
Debug: Using password store: basic
Debug: Will run signal with the following arguments: --password-store=basic
Debug: Additionally, user gave: --use-webgpu-adapter=opengles
NODE_ENV production
NODE_CONFIG_DIR /app/Signal/resources/app.asar/config
NODE_CONFIG {}
ALLOW_CONFIG_MUTATIONS undefined
HOSTNAME archlinux
NODE_APP_INSTANCE undefined
SUPPRESS_NO_CONFIG_WARNING undefined
SIGNAL_ENABLE_HTTP undefined
userData: /home/socek/.var/app/org.signal.Signal/config/Signal
(node:2) [DEP0180] DeprecationWarning: fs.Stats constructor is deprecated.
(Use `signal-desktop --trace-deprecation ...` to show where the warning was created)
After switching input:
[2:0728/133037.116187:ERROR:ui/events/platform/wayland/wayland_event_watcher.cc:47] libwayland: wl_display#1: error 0: invalid object 37
Question:
I have no idea if is this the right forum for this issue. So my initial question is: is this related more to arch linux, or hyprland, or something else?
I have run out of ideas on where to search for clues.
Edit:
After reviewing the logs I found out that first line of log of xdg-desktop-portal-hyprland was pasted wrongly, so I edited and pastet proper one.
if hyprland crashes, please post a crash report
