Hyprlauncher update problem in arch linux
i have a problem to upgrade package hyprlauncher on arch linux.
I have this type of error:
solving dependencies…
warning: cannot apply ‘libicuuc.so=78-64’, dependency on ‘hyprlauncher’
:: The following package cannot be updated due to unmet dependencies:
hyperlauncher
:: Do you want to connect a higher package when upgrading? [y/N]
error: action could not be applied (did not take effect)
:: cannot apply dependency ‘libicuuc.so=78-64’ required by hyprlauncher
if you don’t have any -git packages, this is an arch packaging issue. If you use AUR, just uninstall launcher and reinstall it after update.
@vaxry The dependency on hyprlauncher is libicuuc.so=78-64 which only exists for now in core-testing : Arch Linux - icu 78.1-1 (x86_64)
The icu dependency on core is still in the version 76.1: Arch Linux - icu 76.1-1 (x86_64)
Not everyone uses core-testing, and hyprlauncher being in the extra repository should not depend on a package in core-testing
It has moved to extra from testing
checkupdates | grep ic
icu 76.1-1 → 78.1-1
Oh, literally 30 minutes ago :joy:
it is not from git and aur. its from arch extra repo. i uninstalled this package but now i cannot install it anymore y this issue
nvm it was installed today without this error
